Author Topic: Good source for brass or ally disks 5 pieces of 40mm diameter x 12mm?  (Read 21426 times)
Offline bry1975
    • http://www.satintime.co.uk
 :D
Afternoon chaps,
Can anyone recommend a good source for some decent brass or ally 5 pieces of 40mm diameter x 12mm thick?
I can refinish the blanks here but can't cut them down or part them off as only have a wood lathe with metal chuck and faceplates and YES I need a proper lathe.  :(
TIA
Bry
You can download this catalog (ue ). I know they do blanks.
http://www.m-machine-metals.co.uk/
Although blanks are usually 1" / 25 mm.
It would help if you gave some indication of you location, there may be someone who uses a supplier local to you who is willing to slice off to your dimensions .. :thumbup:
BC
Offline Jasonb
Whats wrong with a hacksaw, wont take long in brass with a sharp new blade.
College engineering sill saw balanks of a bar but there is likely to be a charge.
http://www.collegeengineering.co.uk/
Offline bry1975
Thanks chaps,
I've emailed the two links mentioned and will wait and see.
Offline HS93
I use
http://www.ringwoodprecision.com/
http://cgi.ebay.co.uk/160477659264?ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2Fi.html%3F_from%3DR40%26_npmv%3D3%26_trksid%3Dm570.l2736%26_nkw%3D160477659264%26_fvi%3D1&_rdc=1
http://stores.ebay.co.uk/Ringwood-Precision-Engineering/Aluminium-Round-Bar-/_i.html?_fsub=681408012&_sid=32977372&_trksid=p4634.c0.m322
they are very good speedy and will cut to lenth they also do via ebay but I find it better to ring, he is a nice bloke to deal with never had a problem with them
                                                            :nrocks::ddb:  :ddb: Peter :ddb: :ddb: :nrocks:
Offline timeone
Roy at ringwoodprecision  is a top guy he is very helpful and will do what ever you need he has a full machine shop so can do anything.
jason
Offline bry1975
Thanks Jason. :D
lordedmond
Try here for the ali  not sure about the brass   one point is NO VAT
I have had stuff from him no problems
http://www.plhillsales.com/index.asp
Stuart
Offline bry1975
Thanks Stuart.
Offline HS93
Offline bry1975
Re: Good source for brass or ally disks 5 pieces of 40mm diameter x 12mm?
« Reply #10 on: August 03, 2011, 04:48:01 PM »
Thanks Peter,
I'm now going down the wood route.
Bry
Offline HS93
« Reply #11 on: August 03, 2011, 05:23:53 PM »
Thanks Peter,
Bry
Can you get wood brass  ???     :lol:
                                :ddb:  :nrocks: :ddb: Peter  :ddb:  :nrocks: :ddb:
« Reply #12 on: August 03, 2011, 07:20:38 PM »
                                 Peter
I doubt it ..... but you can get woods glass
                 which rhymes with wood brass
 :nrocks: :nrocks: :nrocks: :nrocks: :nrocks:
