Author Topic: My way to center on a round table.  (Read 7869 times)
« on: June 28, 2011, 04:35:37 PM »
For a wail ago I brought a round table here in Sweden, not a fancy one, it was radar cheap.
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0338.jpgMy way to center on a round table.
I discover that in the middle it was a 8 mm threaded whole.
Then I was searching for a chuck, and found one in USA. The chuck come with a back plate and after some turn on the lathe it was ready to use.
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0339.jpgMy way to center on a round table.
But it was impossible for me to get it in center. I’ll tried times after times but I’ll never got it right.
I was very closed to write to you and ask for advice, but one night I wake up and I have an idea.
The same day I’ll begin to make a jig of brass, threading 8mm and in the middle a 4 mm silver steel.
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0340.jpgMy way to center on a round table.
Then I mount it on my round table..
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0341.jpgMy way to center on a round table.
.. and I have to make a small tool for fasten it, and then I measured the difference when I turn the table round and it was just 8/100 mm so I was pleased.
On the jig I can then mount some brass shaft..
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0342.jpgMy way to center on a round table.
..and it fit very well to my chuck. (of cource I can use many dimensions here).
http://i1123.photobucket.com/albums/l558/Benni_Svensson/Round%20Tables%20Mod/DSCN0343.jpgMy way to center on a round table.
It’s not the big thing that makes the different, it’s the small one.   :D
Re: My way to center on a round table.
« Reply #1 on: June 28, 2011, 04:59:45 PM »
Whats the runout with something in the chuck jaws?
I went similar route 12 years ago but a lot more rigid and less parts. You may find slapping the chuck on its way out.
In the end drilled the chuck through and tapped in to RT, it was bought for one purpose and has done 100's of thousands of revs.
« Reply #2 on: June 28, 2011, 05:18:56 PM »
No my problem was that I coudent center the chuck, it was fasten with four bolts and it was inpossible to center. The chuck is ok and it's now center within 8 / 100 mm.
