Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
The Shop
Tools
Web cam centre finder
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Web cam centre finder (Read 11900 times)
modeldozer
Sr. Member
Valencia, Spain
on:
June 26, 2011, 07:29:54 PM »
Hi all madmodders,
I have built this web cam centre finder about two years ago to aid in setting up on my CNC router. I particularly use it when setting up PCB for drilling. I use it with a program aptly called Centrecam.
For this I used the innards from a Logitech Webcam C120 but can be adapted to any cam with the sensor in the centre of its PCB. I would suggest a better quality cam as the drivers from some of the cheaper ones don’t always work with Mach3.
Care must be taken when turning the rear housing to have the inner lip where the board sits square to the threaded hole in the back. The arbor is turned to final diameter (to suit whatever collet of your choice) fitted and locktighted in the housing to ensure alignment. All shoud be clear from the pics and drawing. Only the dimetions for the PCB "seat" are critical.
Once all assembled the crosshairs in Centrecam are calibrated to indicate true centre by rotating the cam in the spindle around a point (any marked out cross lines).
To use it with Mach3 both the Centrecam and Mach windows must be open on the desktop and the Mach one must be the active one to move your CNC.
Abraham
PS. Have attached the drawing in PDF format, but if anyone wants it in a particular CAD format just let me know (am using TurbocadV14Pro and can export most common formats)
Logged
Brass_Machine
Administrator
Hero Member
Re: Web cam centre finder
Reply #1 on:
June 26, 2011, 09:49:56 PM »
I like this! I have been wanting to build on since I saw it in Digital Machinist! Well done. I am going to do this.
Logged
modeldozer
Sr. Member
Valencia, Spain
Reply #2 on:
June 27, 2011, 10:16:58 AM »
Hi Eric,
Glad you like it. Like I have mentioned, I find it most usefull aligning and setting up for PCB drilling, and also with the circular "hair" in Centrecam very usful when setting up on any hole/bore. With the cam around 50mm above the surface one can get to 0.001mm of the target (depending on the accuracy of your leadscrews/drive system).
Abraham
Logged
HS93
In Memoriam
Hero Member
Reply #3 on:
June 27, 2011, 01:24:49 PM »
Thank you for that I orderd a camera of ebay nice and cheap and I have the ally so it wont be long befor I get turning.
Peter
Logged
raynerd
Madmodder Committee
Hero Member
Reply #4 on:
June 27, 2011, 01:42:09 PM »
Dito !!
Many thanks for the info.
Logged
https://www.youtube.com/user/craynerd
Projects at -
www.raynerd.co.uk
Hero Member
Kempton Park, South Africa
Reply #5 on:
June 27, 2011, 02:10:32 PM »
Abraham,
What a great idea
Logged
modeldozer
Sr. Member
Valencia, Spain
Reply #6 on:
June 27, 2011, 04:30:22 PM »
Hi all,
Glad you fellows like it.
One thing to remeber is to calibrate (in Cenrecam it´s called inicialize), recently I have replaced the computer that runs Mach3 and forgot to redo it. firt job was out by quit a few mm´s. Normally I rotate the cam for the firts coner/hole on a job to make sure, but as things go was in a hurry (6hour part to run) and it was out. Luckaly their was enough "spare/waste" material on the outsides so not to big a blunder
Abraham
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Shop
Tools
