Author Topic: Spin Indexer Update - convenient indexer for mounting in milling vice  (Read 13394 times)
Offline cfellows
I am something of a creature of convenience if it doesn't sacrifice accuracy too much.  Anything which will fit in my milling vice instead of needing to be fastened to the milling table (and zeroed in) is a win as far as I'm concerned.  I've been wanting to build a simple indexing device to fit in my milling vice for years, but everytime I started thinking about it, I got hung up on details and abandoned the project.  Turns out I had this spin indexer that I had bought at Enco many years ago.  It was real bottom of the barrel as far as quality goes and I rarely used it.  I had milled the feet off of it several years ago so I could clamp it in my vice, but it still stood up pretty high.  Also, I hadn't gone to a lot of trouble to make sure the axis was parallell to the vice jaws, in any direction.
Tonight I drug it out, sawed off the rest of the base, then milled the bottom flat and parallel with the axis.  Next I milled a flat on each side to register with the vice jaws.  After considerable fiddling and a number of passes, I got the two side flats parallel with the axis to within a couple of thou end to end.  Since I do mostly short work, like gears, that accuracy will be more than sufficient.
Here are a couple of pictures showing the flats and showing the indexer mounted in the vice.  Think this will get a lot more use now!
http://s192.photobucket.com/albums/z195/cffellows/45976caf.jpgSpin Indexer Update - convenient indexer for mounting in milling vice
http://s192.photobucket.com/albums/z195/cffellows/2b93e922.jpgSpin Indexer Update - convenient indexer for mounting in milling vice
PS:  You can see a large void in the bottom where I cut off the base.  Won't hurt anything, but... Also, there's a lot of bondo coating the surface to make it pretty.  Again, won't hurt anything now!!!
Chuck
I've got one of the newer Spindex's from Enco. Not to bad a quality.
I was going to mount it on a piece of aluminum plate to make it easier to bolt to the mill table.  :dremel:
Still undecided if I'll do that or not. Need to think procrastinate about it a bit more.  :med:
Offline TroyO
Are the tops of vise jaws good for indexing from? I've seen other projects do that before and wondered about it... I don't think mine meet exactly. Hmm, maybe they do when clamped and "tapped down". I will have to run some tests and find out. If not then maybe I need to load them and tap them down like I'm setting up a part and skim the jaws.
I have a spindexer and I haven't even unboxed it in anger yet, LOL. Another project hanging out in the list. It's now on the list somewhere behind checking my vise setup and making sure the tops of the jaws are level...  :doh:
Offline cfellows
The indexer doesn't sit on top of the jaws.  The flat bottom sits on the bottom of the vise.  The ledge left by milling the flats on the sides sits about .050" above the top of the jaws.  The horizontal alignment of the jaws is adjusted when the vise is mounted by using a dial indicator in the mill spindle and running the table back and forth on the x-axis.
Chuck
"procrastinate" I thought that I heard you say you were going to drop this word from you vocabulary. Just so you know, I am keeping an eye out for you.  :lol: :lol: :lol:
Well then Don, you must be getting old. I expected a comment from you on my new project I posted in "Projects"  :lol:
So it's fair that I can use that word, right, since you missed my post there?  :wack:
I didn't really miss it Bernd, I just did what I said you couldn't do. Your right on the getting old, just had another one of those so that's out of the way for another year. I have also got another years experience at procrastination. Now if I could figure out how to un-smoke all those cigarettes, un-breathe all that dust and dirt and paint fumes then I would have it made.  :D :D
I did something very similar a while back Chuck.
But I wasn't quite so free with the cutters on mine, I just made the base small enough to fit into the vice, and had it sitting on parallels to keep it level, as I also wanted to fit a T-slot bar as well, so it could be mounted to the table directly..
http://www.homemodelenginemachinist.com/index.php?topic=2681.0
Spindexers are a real nice piece of kit to have in your arsenal, relatively cheap, and you have access to every degree in a circle by using the vernier holes.
