Author Topic: Flash suppressor vent cutter  (Read 21886 times)
Offline No1_sonuk
« on: June 18, 2011, 08:36:34 PM »
Does anyone know a supplier of the cutters for flash suppressor vents?
What I'm after is for the vents in the attached photo (it's an M16A1 flash suppressor).  It looks like it's a trapezoidal section.
While I can buy the particular part I want to make, there are others that aren't available.
Thanks
Re: Flash suppressor vent cutter
« Reply #1 on: June 19, 2011, 01:08:50 PM »
Hi Tim
You could use a Gear cutter ,, #1  ,, that would be used for cutting a rack .  Just need the match the shape to the nearest DP cutter .
Offline No1_sonuk
« Reply #2 on: June 19, 2011, 01:22:19 PM »
Good idea.  Hadn't thought of that.  :thumbup:
