Author Topic: cheap rev counter!  (Read 15515 times)
Offline jim
cheap rev counter!
« on: June 03, 2011, 04:51:57 AM »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120443914027&ssPageName=STRK:MEWNX:IT#ht_1118wt_1139
just bought one of these (for one of my motorcycles). its the first cycle speedo that i've seen that has a RPM function.
could be a cheap and easy way of doing a rev counter?
bothe the lathes and mill have speed readouts, so not much point in me trying to fit one to one of my machines!
Re: cheap rev counter!
« Reply #1 on: June 03, 2011, 06:28:08 AM »
Hi Jim,
Any idea of the max rpm it will display? I used a cycle computer (without an rpm function) on my old mill, making it believe it was on a 1667mm circumference wheel and reading out in kph. Multiplying the display by 10 then gave the rpm (e.g. 45.6kph = 456rpm). But it didn't expect anyone to pedal faster than 99.9 kph, limiting it to 999 rpm.
Wilkinsons sell one with "AS 11G" on the front for £8 which has an rpm function. I've got one of those now, and despite what its Chinglish instructions say, it will go up to at least 3000rpm.
One note of caution: the sensor heads contain a tiny glass encapsulated reed switches. Very fragile, as I found out the hard way.
Offline metalmad
« Reply #2 on: June 08, 2011, 04:40:31 AM »
HI guys
does anybody know of a cheap engine taco that can be used on singles as well as multys?
A little bit every day, sometimes the same little bit!
Offline jim
« Reply #3 on: June 08, 2011, 08:47:36 AM »
i would love to know myself!!
i've bought a cheap one before for multi cylinder and tried to adjust it on the back, does anyone know how they could be adjusted ???
Offline John-Som
    • Start Model Engineering
« Reply #4 on: June 08, 2011, 09:27:57 AM »
Anyone fitting an RECL electronic ignition system can buy a plug in digital rev counter. I am currently building the Upshur vertical 4 stroke and the rev counter is a neat addition and good value at £11.00 Inc postage.
http://www.apacheaviation.co.uk/Ignition_Systems/ignition_systems.html
John-Som
start-model-engineering.co.uk - a friendly place for model engineering beginners
