Author Topic: Slitting Saw Arbor  (Read 11000 times)
Offline Chuck in E. TN
  • USAF Retired
Slitting Saw Arbor
« on: June 02, 2011, 10:21:13 AM »
I need to make an arbor for a slitting saw with 1” diameter mounting hole. How much bigger diameter arbor do I need? Will 1 1/8” material be enough or should I use 1 ¼” and why?
Arbor will be straight shank, ½” diameter, with a larger piece threaded on.
Chuck in E. TN
Chuck in E. TN
Re: Slitting Saw Arbor
« Reply #1 on: June 02, 2011, 10:44:43 AM »
Chuck,
The answer is (as usual), "It depends."  Commercial arbors for ø1.000 mounts have a 1.375 to 1.750 OD flange.  I have a couple of homemade arbors with a 1.200 OD, though that is more a factor of having started with ø1.250 bar than any specific design intent.  We need more information (drawings?) to really advise.
lordedmond
« Reply #2 on: June 02, 2011, 11:00:48 AM »
  • USAF Retired
« Reply #3 on: June 02, 2011, 11:43:55 AM »
Yes, I started that thread. Had problems getting Bogs C-o-C to print. Got it printed today.
Chuck in E. TN
Chuck in E. TN
