Author Topic: A little lifting aid  (Read 14710 times)
Offline Trion
« on: May 21, 2011, 05:13:16 PM »
As was pointed out, some equipment in my shop is getting a bit heavy to lift. That shouldn't be a problem any more :D
Needs some cleaning, and an oil shift. Might be a problem with sagging under load.
A few of the battery poles need a bit of attention  :poke:
But it is working. Even came with a charger :)
It was free by the way :D
Offline dickda1
Re: A little lifting aid
« Reply #1 on: May 22, 2011, 12:49:43 AM »
I was very jealous about your obtaining this item and even more so when I read it was free. :bow:
Lucky, Lucky
Dick
Skype: VladTheChemist
Offline rleete
« Reply #2 on: May 22, 2011, 09:44:50 AM »
Yeah, but it's too tall; he'll never get it in the door!   :scratch:
Baldrocker
« Reply #3 on: May 22, 2011, 10:35:08 AM »
Easy! just use it to raise the roof. :loco: Or thinking latterally
lay it on its side.
anon e mouse.
lordedmond
« Reply #4 on: May 22, 2011, 11:56:08 AM »
Although you probably know the trick to clean corroded battery post others may not
just get a kettle full of boiling water and pour it on the the battery post dry off and re grease Vaseline is as good as any ( you can get some special stuff that changes colour when corrosion starts )
Stuart
Baldrocker
« Reply #5 on: May 22, 2011, 09:54:02 PM »
Add some bicarbonate of soda to the hot water.
br
