Author Topic: jerry howell farmboy  (Read 15642 times)
Offline jonesie
« on: May 15, 2011, 09:08:30 PM »
here are a couple  of pics of my farmboy  in the process of being put  together. need the small spring for the catch arm, the put on other flywheel with the gov. on it. hope to have it running soon, then hope to post a video. jonesie
Re: jerry howell farmboy
« Reply #1 on: May 15, 2011, 09:38:52 PM »
Nice! Looking forward to the video.
Are those delrin/acetal mounts for your tank?
Offline KB3RLJ
« Reply #2 on: May 15, 2011, 09:43:18 PM »
Beautiful. Is that a kit you started with? I'm wondering what a good novice kit might be to start with.
Offline cfellows
« Reply #3 on: May 15, 2011, 11:57:39 PM »
Nice work!   That's going to be a good looking engine.
Chuck
« Reply #4 on: May 16, 2011, 01:17:33 AM »
Nice looking engine:- good job done  :thumbup: :headbang:
« Reply #5 on: May 16, 2011, 05:48:39 AM »
Nice work, a movie please  :clap:
Offline jonesie
« Reply #6 on: May 16, 2011, 09:43:27 AM »
tank mounts are 101nylon. this is not a kit it is from bar stock, the flywheels are casting. the frame is alum. and is made in 2 pieces for easy machining.the prints are from jerry howell, his son now sell the plans and they are excellent. i have also build his i/c powerhouse which is from bar stock,and is a good one to start with, and a good runner. i need to hook up ignition,and assemble the gov. on other flywheel, and then to start. just got a new video cam. so when i get it figured out i hope to post videos of both. for me making the models is easier then posting pics. or videos.the plans can be gotten for alan howell at jerry howells site at jerry howell .com. thanks for looking. jonesie
Offline jonesie
« Reply #7 on: May 20, 2011, 11:01:27 PM »
couple more pics of the assembly of the farmboy. need to get a longer spring for the gov. balls then hook up ignition. i am using an s/s ignition, not going to wire the spark save to start want to make sure it is running good first. hope to get it started next week sometime , then with a little luck i can get a video posted. thanks jonesie
« Reply #8 on: May 21, 2011, 05:16:10 AM »
Looking very nice  :thumbup:
