MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
MadModder
The Shop
Metal Stuff
Building A Molding Bench - Pictures Galore!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Building A Molding Bench - Pictures Galore! (Read 22752 times)
CallMeAl
Jr. Member
I came, I saw, I wondered how to do it!
on:
May 08, 2011, 12:11:28 AM »
Last time I posted a project on MadModder I was casting a base for a solenoid engine. I had problems with my sand mix and vowed to switch to an oil based sand. I ordered the sand and set about to build a molding bench to hold the sand and try to contain the usual sand mess I make. I also wanted a bench that I could roll around and use as a work table when doing any casting so it needed to have a fold down back. Here is some photos of the bench construction. This mostly about wood working, but it ends with metal casting so I'm putting it here instead of under the wood section.
Building the carcass:
Installing casters to make it mobile:
Plastic mixing tub fitted:
Full extension drawer for tolls etc.
Tub chute edges:
Fold up top and bench grate slats:
Ready paint and sand:
Sand arrived about 200 lbs. of 250 lbs. ordered, bench painted:
Time to test it out. I turned up a quick and dirty pattern for a rammer out of pine, no paint, just waxed it. I was in a hurry to try out the virgin sand.
Turned out just fine for a quick test, but it would be better if I took the time to make the pattern better and put a nice smooth coat of paint on it.
The bench seems to work like I hoped it would. The sand is a little sticky, but it should improve with use.
Thanks for viewing.
Al
Logged
I skin cats my own way!
raynerd
Madmodder Committee
Hero Member
Re: Building A Molding Bench - Pictures Galore!
Reply #1 on:
May 08, 2011, 03:14:58 AM »
Great work mate, clearly handy with brown stuff as well as the shiny stuff!! Nice bench.
Logged
https://www.youtube.com/user/craynerd
Projects at -
www.raynerd.co.uk
Guest
Reply #2 on:
May 08, 2011, 05:10:16 AM »
Hi Al
Now thats got to be the Rolls Royce of moulding benches
nicely done
Did you fined the sand hard to ram up ?
Logged
Noitoen
Full Member
Reply #3 on:
May 08, 2011, 07:45:33 AM »
For not ramming up so good, the sand was fined £50,00.
Logged
Hero Member
Kempton Park, South Africa
Reply #4 on:
May 08, 2011, 08:40:18 AM »
Hi Al,
A very nice job done there
Logged
saw
Hero Member
lucky amateur
Reply #5 on:
May 08, 2011, 09:24:20 AM »
Nice work
Logged
foozer
Full Member
Camano Island WA
Reply #6 on:
May 08, 2011, 03:35:01 PM »
Nice work, where did you order the sand from?
Robert
Logged
CallMeAl
Jr. Member
Reply #7 on:
May 08, 2011, 04:28:58 PM »
Hey Rob: Thanks, I wouldn't say it was the Rolls Royce, more like a Geo Tracker - who would put sand in a RR? The sand seemed very easy to ram up, a slight bit sticky, but I ain't complaining it should better with use and blacker also.
craynerd: I did some of of the "brown" stuff before I found the religion of metal (though I was welder/mechanic for 25 years). Now I do wood things to make it easier to do metal things.
foozer: Thanks. The sand was ordered from: IFSCO. Check out their website:
http://www.foundry-supplies.com/home.html
Very easy to work with.
Logged
Brass_Machine
Administrator
Hero Member
Reply #8 on:
May 08, 2011, 07:17:42 PM »
Nice work!
Logged
Powder Keg
Global Moderator
Hero Member
Machinist Extraordinaire
Reply #9 on:
May 09, 2011, 07:25:38 AM »
Next you'll be needing a muller\o/ I just mix a little 2 stroke oil in my sand when I mull mine. a little goes a loong way!!! That is about like my bench. I find it really easy to use. Great job!!!
Logged
Wesley P
arnoldb
Hero Member
Windhoek, Namibia
Reply #10 on:
May 09, 2011, 04:25:54 PM »
That's VERY nice Al
, Arnold
Logged
CallMeAl
Jr. Member
Reply #11 on:
May 15, 2011, 11:29:44 AM »
Thanks Arnold!
Power keg: Thanks. I do have a muller, I built one awhile ago.
Here is a short video of the build and of it in action, works very well though I have some improvements in mind:
https://youtube.com/watch?v=tU7zJJ_DCTo
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
The Shop
Metal Stuff
