Author Topic: stuart turner 10v help  (Read 24685 times)
Offline earnie
« on: April 30, 2011, 03:59:30 PM »
hi all this is my first post here
i recently aquired a stuart 10v kit and need the book on how to build this or drawings
any and all help would be appreciated
this kit is about 60% machined
there are many questions to be asked but i cant logically ask these till i have plans or books
i ordered a plans set from stuart dont have an idea when it will arrive as i live in the us and the plans are coming from the uk
i see a book was published regarding this model called " building  a vertical steam engine from castings " by andrew smith, revised by pengwern
does anyone have a copy of this book or where one could source this thanks
Re: stuart turner 10v help
« Reply #1 on: April 30, 2011, 04:21:11 PM »
Hi Earnie
Welcome to the Forum  :thumbup:
UK source herewith:
http://www.camdenmin.co.uk/construction-manuals/building-a-vertical-steam-engine-p-2094.html
Also apparently on Amazon US for some horrendous prices 'used'
IF it's the same book ??
Dave BC
« Last Edit: April 30, 2011, 04:24:23 PM by Bluechip »
« Reply #2 on: April 30, 2011, 04:36:52 PM »
Hi earnie is it the drawing that you need?
Offline earnie
« Reply #3 on: April 30, 2011, 04:40:10 PM »
yes i need the drawing and any and all advice on these things thanks
« Reply #4 on: April 30, 2011, 07:08:24 PM »
pm sent  :D
Offline earnie
« Reply #5 on: May 02, 2011, 12:02:10 AM »
thank you sir email received great drawings
thanks
« Reply #6 on: May 02, 2011, 04:19:41 AM »
You are welcome(not sir I am Benni  :D)
« Reply #7 on: May 03, 2011, 11:47:40 AM »
Hi Earnie, welcome to the pack :beer:  I'm glad you got some drawings, and hope to see some metal chips soon, and see you on your way to a fine engine that runs.  It's always great to see new names and new projects on the site, the more the merrier.  Good luck with that Stuart,  :beer:  Cheers, Jack
Offline earnie
« Reply #8 on: May 05, 2011, 03:36:34 PM »
thanks gents, this thing does require some work, however im ok with it,
since i dont have a lathe= :( i have turned over the centering and drilling of the flywheel,the manufacturing of the eccentric bushing, and mannufacturing of the piston to a freind at work
the rest of this i can handle here at home :)
thanks for the help here
« Reply #9 on: May 05, 2011, 03:58:29 PM »
It's good that you have a friend to help you, but it is a heavy way to build a engine on  :doh:
Offline earnie
« Reply #10 on: May 05, 2011, 04:51:03 PM »
thanks benni, the drawings you sent show me that at least 70% was finished
i beleive that i am off in a good way to finishing this
i will put up some pics soon of what i have
« Reply #11 on: May 05, 2011, 04:58:17 PM »
I am very glad that I could help you. :thumbup:
