Author Topic: Hit n Miss Engine ,,,,to MR D Kerzel's design  (Read 128131 times)
Re: Hit n Miss Engine ,,,,to MR D Kerzel's design
« Reply #25 on: April 26, 2011, 02:43:18 PM »
Missed wot ?
John S.
« Reply #26 on: April 26, 2011, 04:37:21 PM »
A bit more whittling of the cylinder block tonight ,, bored out and under cut the section for the water tank .
Then back to the mill ,,, removed some of the excess material to from the tank
Used a end mill with a 3mm rad to form the tank top
Milled the tank hole square
Added a rad to the top edge of the tank
 next a slot is milled to join the tank to the water jacket
And thats it for tonight
« Reply #27 on: April 26, 2011, 05:14:32 PM »
Looking great Rob  :bow: :bow: :bow: :bow:
I bet this is a plesant change from grinding and welding :D :D
« Reply #28 on: April 26, 2011, 06:00:41 PM »
Your'e the man  :bow: :bow: :bow:
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #29 on: April 26, 2011, 06:27:21 PM »
Gee Rob.  I started looking like an engine lickity split.  Looks good, too!
Dean W.
Shop Projects:
Offline metalmad
« Reply #30 on: April 26, 2011, 08:12:05 PM »
looking fantastic rob
I loved making the Kerzel and it so much fun to see someone else do it too
and its easy to see its gunna be great  :D
A little bit every day, sometimes the same little bit!
« Reply #31 on: April 26, 2011, 09:14:48 PM »
Great job you are doing on the Kerzel Rob. There is no such thing as too many photo's although it can be a pain taking them and doing the write up later. I'll be watching through to the end as usual.  :D :D
Offline metalmad
« Reply #32 on: April 27, 2011, 07:56:41 AM »
Hi Rob
u inspired me to get back to my Kerzel mate
here is the first run vid before tuning, I know its running like a hairy goat, but a bit of a tune will fix that another day  :thumbup:
http://www.flickr.com/photos/61672544@N06/5661014990/
« Reply #33 on: April 27, 2011, 09:16:13 AM »
Nice  :clap: :clap:
« Reply #34 on: April 27, 2011, 11:11:04 AM »
Thanks Lads  :thumbup:  ,,,,, pleased there is not too many photos ,,  :)
Dean ,, it must be getting near  that time of year when you do an engine build  :poke:  :)
Pete  :clap: :clap: :clap: :clap: :clap: :clap:  ,, great to see a runner  :thumbup:  strange name for an engine  :scratch:  ,, i see you have extended the crank so a pully could be fitted ,, i had  planning to do the same  :dremel:  ,,,,, I noticed your under fuel tank arrangement   :med:  ,,,,, i like that idea ,, may do likewise to my engine .
« Last Edit: April 27, 2011, 11:15:07 AM by Rob.Wilson »
« Reply #35 on: April 27, 2011, 12:06:46 PM »
Hi Robb, good to see you making progress so well, and quickly, you should have er running in no time at all!  Looking forward to this whole build, so far, very nice work.  I'm glad I got the chance to see one running too, thanks to he who posted his old build, kind of brings life into the picture. :nrocks: :beer: Cheers, Jack
« Reply #36 on: April 27, 2011, 05:18:04 PM »
Cheers Jack  :beer: ,,,,,,,,,,,,,,, i am getting there  :)
A bit more tonight ,,,,,, :dremel: the cylinder block needs a bit more profiling ,, job for the R/T .
The block was held in a 4 jaw chuck and the bore clocked in to the R/T axis .
then one side was clocked in to the mill X axis , this is so the head bolt holes and radiussssss will be in the correct position , making note of the R/T dial
reading.
Then finally the job was clocked into the mill spindle ,,,,,, zeroing the mill dials .
Now we no were the job is in relation to everything ,, time to start milling  :dremel: , first off the head bolt holes were spotted ,
Next the 180 deg radius was milled on the lower section of the block
Then the job was spun around and the other side milled
Thats it for tonight  :)   must admit this is a fun engine to build  :ddb: :ddb: :ddb:
« Reply #37 on: April 27, 2011, 06:07:16 PM »
I just love to see your'e work, all the time I'll learn somethong, thanks for showing Rob  :thumbup: :thumbup:
Offline metalmad
« Reply #38 on: April 27, 2011, 06:45:50 PM »
love this post
keep up the great work
and remember if u make the crank on the regulator side a little longer for lockout clearence, u may be very glad u did  :wave:
pete
« Reply #39 on: April 28, 2011, 05:22:51 AM »
Nice to see a rotary table being used properly......  :thumbup:
(As in.... Finding centre, and keeping track of where the cutter is, in relation to r/t positions).  :scratch:
Well..... I know what I mean!  ::)
« Reply #40 on: April 28, 2011, 10:16:38 AM »
That's looking great Rob, the milling of the radii is a definite plus, and gives it character.  With that size hopper, it should run for about forever without overheating :ddb: :headbang:  how big is that block before you machine it all out?  I've got to make sure I've got enough raw stock for when I get to it.  Great build, and there's never too many pictures :lol: :beer:  Cheers, Jack
Offline cfellows
« Reply #41 on: April 28, 2011, 10:34:24 AM »
Nice work, Rob.  Your rotary table / 4 jaw chuck set up looks identical to mine.
Chuck
« Reply #42 on: April 28, 2011, 11:49:46 AM »
A question, why is it call a  Hit n Miss Engine   :zap:
« Reply #43 on: April 28, 2011, 04:57:53 PM »
Cheers lads  :beer: :)
Jack  ,, a lump  1 1/2" x 2 1/2" x 2 3/4"  will do the cylinder block ,,,,  fairly small engine  :med:
and here is a shot next to Johns water jacket  ::)
Hi Benni ,,,,,,,,,,,,,, its a hit and miss ,, because when the engine is not under load ,, it only fires now and then ,, Fire /hit ,, free wheel for a few revolutions /miss
<iframe width="425" height="349" src="
" frameborder="0" allowfullscreen></iframe>
And how is you engine coming along Benni  :poke: :whip:
« Last Edit: April 28, 2011, 05:07:52 PM by Rob.Wilson »
« Reply #44 on: April 28, 2011, 05:23:17 PM »
More photos of tonight's efforts  :dremel:
Made a start on the bearing blocks ,, a bit more 4 jaw chuck work .
I used larger than required stock so the was more to get hold of in the 4 jaw .
the excess on the back face was milled of with a fly cutter .
Still a bit of work to do to them ,,, thats for tomorrow as we have a  day off work in the UK ,,,,,,,,dont you just love the royal family  :ddb: :ddb: :ddb: :ddb: Shop time  :)
  • Country: za
« Reply #45 on: April 28, 2011, 05:57:54 PM »
Rob,
That's looking rather splendid  :thumbup: :thumbup: :thumbup:
Offline metalmad
« Reply #46 on: April 28, 2011, 08:04:54 PM »
lovely to watch  :nrocks:
« Reply #47 on: April 28, 2011, 08:22:47 PM »
What the.....
I`ve only gone out of thread for a day and you have nearly built it. Man, I really am slow  :bang:  Nice build and please please, as many pictures as you can, there are never too many especially when your trying to follow them! Some really good setups and you horizontal mill looks to get some action. Just curious, what determines whether you choose to use your horizontal setup or a standard vertical? - I know there is always more than one way "to skin a cat", but just curious how you personally decide.
« Reply #48 on: April 29, 2011, 04:16:08 AM »
Great to see you making an engine rob  :thumbup: Beautifully crafted from solid bar, I'll definitely be watching this one - there are so many good build logs on here I'll have no time to do anything of my own  :lol:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #49 on: April 29, 2011, 05:13:03 AM »
 :clap: :clap: Good going Rob  :thumbup:
 :lol: Shop time's definitely better than watching the royal wedding!
:beer:, Arnold
