Author Topic: 170 Piece TiN Coated HSS Twist Drill Bit Set With Drill Bit Gauge for $44.99  (Read 9749 times)
Offline PTsideshow
Received an email from woodcraft, they have a sale on till 4/30/11 170 Piece TiN Coated HSS Twist Drill Bit Set With Drill Bit Gauge   for $44.99   $55.00 off the regular price.  Since they are the smaller sizes that tend to break with use.
Breaks down to about .26ยข each If your interested
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
I was in the area the store is located in so I stopped in.
http://i35.photobucket.com/albums/d200/ptsideshow/Wood%20turning/WT25.jpg170 Piece TiN Coated HSS Twist Drill Bit Set With Drill Bit Gauge for $44.99
All look good the larger sizes near 3/8" are the ones that only have 5 each. Very nice quality steel box that can hold some extra drills in each compartment. Looks like I can clean out the drawer with envelopes. the drill gauge is also metal not plastic.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Sales must come from much higher up than the retail location these days.  I just received a flyer for Canadian Tire today showing a virtually identical set with about the same sale price.  Coincidence?  Maybe.
I've looked at the set a few times myself, but I don't do enough repeat work to need so many of the same size bits.
-Sparky
