Author Topic: My Kwackers RT controler  (Read 25278 times)
Offline HS93
« on: February 17, 2011, 06:52:18 AM »
Here  is my version of the kwackers  RT divider etc, I was fortunate that Steve  MR Kwackers helped me out as he had a lot of bits over from builds and was good enough to let me have them I did decide though to change the driver board so it would fit in the case I had decided to use supplied by RS.
I got hold of a XYDrive from eBay a nice neat unit with the newer type of chip (so I have been told) that runs cooler and only needs a small heat sink supplied fitted with it, as the unit was going to be tugged about I decided that a ally plate to hold the plugs may be an idea, the first set up was the normal XLR type and I used a locking phono 4 pin for the power, this when finished I did not like so a flanged nylon part was turned to fit with a slot for the cable.
I mounted the display by laminating some plastic card 2mm and the milling out to take the screen I drilled for the mounting screws and bonded them in  I cut the aperture for the screen then glued the mount in , the case look’s nice and smooth without the mounting screws, then re fitted the screen, the slot had been milled for the keyboard so that was fitted then just the wiring, I have some foam to fit around the plug exits yet and am going to convert the RT I have very soon. so thanks to Kwackers I have a nice rt controller ready for the metalwork to be finished and then I will be cutting gears and drilling portholes etc
Peter
« Last Edit: February 23, 2011, 06:20:35 PM by HS93 »
Offline HS93
Re: My Kwackers RT controler
« Reply #1 on: February 17, 2011, 06:57:14 AM »
the last few pictures
« Last Edit: February 23, 2011, 06:20:58 PM by HS93 »
Re: My Kwakers RT controler
« Reply #2 on: February 17, 2011, 07:27:36 AM »
Yes, nice work. It is an amazing controller and works fantastically well.  :beer:
« Reply #3 on: February 17, 2011, 09:09:33 AM »
Very cool Peter!
Offline j45on
« Reply #4 on: February 17, 2011, 10:08:32 AM »
Nice job very neat  :thumbup:
That driver looks tiny I originally fitted mine in the case but I had no room left for sockets.
Jason
Offline HS93
« Last Edit: February 23, 2011, 06:21:54 PM by HS93 »
« Reply #6 on: February 17, 2011, 10:42:17 AM »
Nice going Peter  :bow: :bow: :bow: :thumbup:
Offline HS93
« Reply #7 on: February 23, 2011, 04:49:51 AM »
Thank you for that Chap's
 :ddb: Peter  :ddb:
                                           :nrocks:
« Last Edit: February 23, 2011, 06:22:11 PM by HS93 »
Offline z3t4
« Reply #8 on: February 23, 2011, 02:49:59 PM »
That's very nice: well-done!  :beer: It's a very nice implementation of a very nice design. Here I've just drilled my pcb, so ready to start making the rest soon. The multipole (? DIN) connectors look very handy. Where are they from?
Offline HS93
« Reply #9 on: February 23, 2011, 02:59:12 PM »
the XLR on the left is from http://www.arceurotrade.co.uk/Catalogue/Stepper-Motors/Wiring-Accessories  but farnnel or RS have them but a lot more expensive the other plug was going to be for power BUT the pins cannot be protected on the inside of the shroud so where not safe but they where from Maplins or you may know it as CRAPLINS..  the case was from RS .
I thought the amount of moving about that I needed to ancor the sockets down so hence the ally plate. they work great by the way Kwakers did a great job
   :ddb: Peter  :ddb:
                                                              :nrocks:
« Last Edit: February 23, 2011, 06:22:34 PM by HS93 »
« Reply #10 on: February 23, 2011, 03:45:00 PM »
Re: XLR connectors.
For my CNC conversion project I bought 4 decent quality latching XLR plugs and sockets from www.audiospares.com. Including postage and VAT they were only £16.06. Part numbers are AS-CO-P-XLRM4 (XLR 4-Pin Male Connector)  & AS-CO-S-XLRF4 (XLR 4-Pin Female Chassis Socket).
Offline cfellows
« Reply #11 on: February 23, 2011, 05:54:49 PM »
Is there a link to a website for the Kwakers RT controller?
Chuck
Offline HS93
« Last Edit: February 23, 2011, 06:22:53 PM by HS93 »
Offline Chuck in E. TN
  • USAF Retired
« Reply #13 on: February 23, 2011, 06:43:55 PM »
I just ordered a Vertex 4" Rotary Table and intend to follow kwackers controller build also.
Chuck in E. TN
Chuck in E. TN
  • USAF Retired
« Reply #14 on: October 11, 2011, 10:58:48 AM »
I hope it's o.k. to resurect this thread. I am building the kwackers controller for my Vertex RT, but haven't worked on it in a while.
My issues are with making the pcb. I have not been able to get a good transfer of the layout, using the laser toner/iron on transfer method, to etch the board. Is there a source for a pre-made circuit board for this project?
Can I beg someone to make a board for me?
If I should have started a new thread, would one of the moderators move this post, please?
Chuck in E. TN
Chuck in E. TN
« Reply #15 on: October 11, 2011, 04:29:38 PM »
Hi Chuck... sent you a PM about the board.
Offline kwackers
« Reply #16 on: October 12, 2011, 08:46:41 AM »
You sorted now Chuck?
« Reply #17 on: October 12, 2011, 09:50:49 AM »
Gonna attempt to assist. Done a few boards in my time... hope I can do this one.
« Reply #18 on: October 12, 2011, 10:33:44 AM »
Chuck in E. TN
I tried the transfer method once and moved on to using the UV exposure method and never looked back.....
