Author Topic: What exactly are these suited for  (Read 12168 times)
Offline benchmark
« on: January 27, 2011, 04:08:32 PM »
HSS cutter drill bit set titanium drill 6x + wooden box
They look to be a cross between Milling bits and normal drill bits.
See pictures and videos of my collection:
http://dampmaskiner.webs.com
Re: What exactly are these suited for
« Reply #1 on: January 27, 2011, 04:20:39 PM »
HI well ther a mix betwen a drill bit and a mill bit the thing you do with them is drill in to say a thin pece of ally plate then pull the drill in any direcshon to cut out a pece of the plate   sos for speling hope this helps
Offline benchmark
« Reply #2 on: January 27, 2011, 04:48:03 PM »
Thanks for the reply. So in essence they are only for milling (routing) thin metal plates?
Offline Swarfing
« Reply #3 on: January 27, 2011, 05:04:25 PM »
These are for using with things like a rotazip for cutting plasterboard excetera. The idea is you can push straight into the material and free cut.
Once in hole stop digging.
« Reply #4 on: January 28, 2011, 12:26:48 PM »
What Swarfin said... they're a sort of cross between a drill & a routing bit. Dunno how effective they'd be in metal, probably they'd just snap.
« Reply #5 on: January 28, 2011, 12:34:50 PM »
Just give them to someone who works with the brown stuff, they are not accurate enough if working with metal, you could end up with holes all shapes and sizes.
Offline Jasonb
« Reply #6 on: January 28, 2011, 01:51:23 PM »
They are not even that good in the brown stuff so don't give them to me.
J
« Reply #7 on: January 28, 2011, 04:42:44 PM »
They are no good if you just poke them through the work and try to move them sideways.  They are useful for non precision work if once through the material you work them back and forth like a file, obiviously this is really only practical if you are using them in an electric hand drill.
Offline benchmark
« Reply #8 on: January 28, 2011, 05:40:05 PM »
Thanks for the replies guys.
