Author Topic: Found a use for an old A2 machine bolt turned to Panerai Bezel ferrule  (Read 25813 times)
Offline bry1975
    • http://www.satintime.co.uk
Hi chaps,
Just thought I'd show one of the tiny turning jobs I was asked to undertake when I actually had a metal lathe.
I was sent the Panerai 300m Submersible and the chap requested a replacement bezel ferrule to be
machined and fitted the watch was then satin finished.
http://img835.imageshack.us/img835/5534/pannie.jpgFound a use for an old A2 machine bolt turned to Panerai Bezel ferrule
A2 threaded stub.
http://img101.imageshack.us/img101/6514/pan22.jpgFound a use for an old A2 machine bolt turned to Panerai Bezel ferrule
Bezel ferrule is then securely cemented in place.
http://img529.imageshack.us/img529/9785/pan77.jpgFound a use for an old A2 machine bolt turned to Panerai Bezel ferrule
Panerai finally satin finished minus the crown guard and lever.
http://img708.imageshack.us/img708/4364/pan88.jpgFound a use for an old A2 machine bolt turned to Panerai Bezel ferrule
« Last Edit: January 29, 2011, 07:15:44 AM by bry1975 »
Offline ieezitin
Re: Found a use for an old A2 machine bolt turned to Panerai Bezel ferrule
« Reply #1 on: January 26, 2011, 04:03:17 PM »
Nice job Bry. Very detailed,
I take it you had a jewelers lathe?. If so which one?
Anthony.
Offline bry1975
« Reply #2 on: January 27, 2011, 07:48:38 AM »
Thanks,
Nope I'm trained on engineering centre lathes I was using the smallest mini lathe available from Axminster in the uk something like 150W power output!
