Author Topic: spin indexer  (Read 23986 times)
Offline fourperf
spin indexer
« on: January 12, 2011, 10:16:46 AM »
Hi Guys, would anyone happen to know how many degrees apart the 10 holes are on the vernier plate of a spin indexer?
The outer plate has the 36 holes at 10 degrees apart.
the vernier plate has the 10 holes numbered 0 - 9.
I want to be able to index 360 degrees every degree.
I cant wrap my head around the math.
thanks
Mark
Re: spin indexer
« Reply #1 on: January 12, 2011, 11:49:51 AM »
One
If you put the pin in hole 1 you indexed 1 deg 2 = 2 deg, 3 =3 deg, ------------ 9 = 9 deg back to zero and your on 10 deg.
Hope this helps
Re: spin indexer
« Reply #2 on: January 12, 2011, 11:56:45 AM »
Mark,
Unless I have missed something critical here, my "spin indexer" has normal 10° increment indexes on the primary index ring and 1° increment indexes on the vernier index ring.  Thus, I start at the 0° position and move to the (say) 20° position -- and then place my index pin in the (say) 5° vernier hole, remove my primary index pin, and rotate the indexer until the vernier pin drops into the next hole.  I have now moved 25° from my initial position.  Your 0° vernier hole should index when the primary index pin is in any of the 10° increments.  My "spin indexer" is old enough that it has 11 holes on the vernier (0°-10° for double-checking).  It is a shop-made tool given to me by a retiring machinist back in the 1960's.  I know that I have used commercial "spin indexers," but my fingers know my own tool best.
Offline winklmj
Re: spin indexer
« Reply #3 on: January 12, 2011, 01:09:58 PM »
Mike
Offline crabsign69
Re: spin indexer
« Reply #4 on: January 12, 2011, 02:23:29 PM »
Re: spin indexer
« Reply #5 on: January 12, 2011, 08:17:21 PM »
Worked OK for me right now 1/112/11 8:15PM
Offline DeereGuy
    • D1 Adapter Solutions
Re: spin indexer
« Reply #6 on: January 12, 2011, 09:28:57 PM »
Worked ok for me also.
Offline fourperf
Re: spin indexer
« Reply #7 on: January 12, 2011, 10:47:23 PM »
thanks guys for the replys.  The holes in the vernier do indeed have to be 1 degree apart but that would overlap them.  I got the answer on cnc zone to make them (the holes in the vernier plate) 11 degrees apart which makes sense to me.
thanks a lot.
Mark
Offline crabsign69
Re: spin indexer
« Reply #8 on: January 13, 2011, 02:42:37 PM »
it worked for me today but it was not there when i checked it first time.   cool beans man will give it a good reading   thanks  :headbang:
