Author Topic: Milling Machines. Swap....  (Read 11789 times)
« on: January 06, 2011, 08:05:17 AM »
I have had a Chester Conquest mill for almost 2 years now.....
http://www.chesteruk.net/store/conquest_mill.htm
My Pal wants it.
I fancy a Chester Champion V16.......
http://www.chesteruk.net/store/champion16_variable_speed_mill.htm
No problems between us, over the swap.
My replacement machine must have the "same" footprint and weight as the Conquest.
Has anyone used/ owned a V16? Is there any reason why I shouldn't have one?
Re: Milling Machines. Swap....
« Reply #1 on: January 06, 2011, 08:07:06 AM »
Got the Warco equivalent here being converted to CNC, nice machine, well made and very sturdy for that they are.
John S.
« Reply #2 on: January 06, 2011, 08:13:18 AM »
By 'ekl John! That were quick.....  :bugeye:
What I wanted to hear too! Thank you.  :thumbup:
« Reply #3 on: January 07, 2011, 03:35:52 AM »
Anyone else got a comment?
« Reply #4 on: January 07, 2011, 04:17:51 AM »
Hi Dave
What sort of comment ??
Looks like my Warco WM16. Except the table is 700mm on mine, not 500mm.
WM16 table may be a bit wider, can't remember for sure.
Which probably explains why mine is heavier. 90Kg IIRC.
Thought about one of those from Chester, but I did not like where they stick the 'wind up and down' handle.
Works OK. Knows more about milling than I do.  :scratch:
Dave BC
« Last Edit: January 07, 2011, 04:23:53 AM by Bluechip »
« Reply #5 on: January 07, 2011, 04:40:02 AM »
Hi Dave
Dave BC
I was hoping for someone to say they'd got one. "Just watch out for......"
I see the taper is MT2, no R8 option. The T slots are smaller too. (So, new arbors and T nuts/ studding will have to be bought).
Guess there's no problem really......  :thumbup:
