Author Topic: An experimental engine  (Read 75445 times)
Offline arnoldb
  • Windhoek, Namibia
« on: January 02, 2011, 04:29:49 PM »
A little bit of design work... I'm posting in "The Design Shop", as this is pretty much an evolving design!
My long-term goal is an O gauge 060 locomotive with functional tender that's fairly easy and cheap to build and a good no-nonsense runner.  I've learned many valuable lessons from building and running little Fred the loco, and while I love Fred, it has quite a couple of flaws - which I'm not going to attempt to correct, as I like the loco as it is - it carries many fond memories!
While working on my design, I've gained a VERY healthy respect for designers who draw up a model and then proceed to build it - it is a huge challenge!
So far I have spent a lot of time on research - from pointed questions asked in the Boilers section on HMEM to reading and fully trying to understand each bit of information I could lay my hands on relating to boiler design, how steam works in small models, and studying different valve gears to figure out how they work.
I'm slow with CAD - which makes matters worse, so I've resorted to just hand-drawing parts when I've had a bit of inspiration.  And material selection is a bit of a problem; I have to work with what I have available.  O gauge is fairly small, bringing some additional challenges...
I've reached a point where it would be easier to actually make some bits than try and run them through my mind.  Thus, this thread will not be along the lines of a quick and deliberate build to established plans, but a changing work most likely with a LOT of failed bits and re-designs to reach an end goal.  I'll share all the trials and tribulations along the way; maybe there would be some useful information for someone in there.  And if anything's good for a chuckle, that's also fine by me - building boo-boos is more fun than no machining at all  ;)
Experimentation first - I need to see if the idea I have for valve gear will work.  First prize would be full Walschaerts gear - but I have a simplified valve gear in reserve...  For a start I need the basics of an engine - a working cylinder, a way to mount it, simulate a loco drive train and then "play" with the valve gear.
First up, a cylinder along the lines I have in mind - outside admission D-Valve, 10mm bore, 14mm stroke, 5mm thick piston - a rough C-o-C of the plan, and a block of aluminium to make it from:
The block's a bit big; it's 1" square stock about 43mm long.  My design calls for a cylinder block 20mm long, 16mm high and 18mm wide.  So I milled it down to 20mm in thickness first:
Really hogged it to 20.5 mm hence the big chips, then took the last 0.5mm off slowly to get a better surface finish.
As the block had more than enough material left on it to also make the steam chest from, I slit off the top to make the steam chest from and leave the block 16mm high, rather than waste all that aluminium by turning it into chips:
At this point one of the realities of my endeavour kicked in; this cylinder would be quite small...  Not nearly as small as Elmer's Tiny, but still, it would present some workholding issues.  In fact, there was enough material on that aluminium block to make two cylinders from - while making machining easier..., So I started making two cylinders from it.  I marked it out for two, then drilled the first cylinder; a 6mm through hole (just convenient to fit the mill's collet chuck), then 9.8mm, and finally reamed it to 10mm.  The reamer is actually a hand reamer that I chucked in the mill - slowest speed and lots of methylated spirits which I use for cutting fluid on aluminium, and it makes for quite a presentable bore:
The cylinder bore on the right-hand side received the same treatment  :)
With two cylinders-in-making needing port holes drilled, it just seemed logical to have a think around what's needed in terms of valve chests, valve plates and covers.  Cue some small bits of 1mm thick brass:
I couldn't be bothered to set up to mill the plates to size, so a quick bit of filing was in order.  Good for some exercise to work off the effects of Christmas and New Year  ;):
I thought I'd be clever and stick the bits together with some cheap CA glue (Superglue/Crazy Glue):
I did say CHEAP CA glue; it didn't work, and while drilling the first 1.6mm bolt hole, it started coming apart, so I fell back to some of my "friends" for keeping things together; the much underestimated toolmaker's clamp:
The bolt hole is 1.6mm for threading M2 - most of the holes will need drilling out to 2mm clearance later on.
While the going was good, I kept the valve plate fixed to the cylinder block, and laid out one side of the valve holes:
The other side was done simply; clamp up on the side that was done, and remove the clamp on the side to do.  Have I mentioned how convenient the height gauge is for jobs like this ? - I can't believe I took so long to make one!
Some drilling in the mill followed.  I didn't bother to center punch any of the holes (In fact, I've stopped center punching any hole spots for the last couple of my builds!)  I just located the first (top left hand) drilling position as accurately as I could, zeroed, the dials on the mill, and co-ordinate drilled the rest off readings of the handwheels - keeping backlash in mind:
The center drill I used (actually a spotting drill followed by a normal drill would be better - but I don't have spotting drills) has a convenient 1mm tip - but it does make a larger hole - it ends up at about 1.1mm - but OK for the valve plate and spotting through to the engine block.
Some milling followed.  Seeing as I'd done things by setting the mill dials, this was quite easy.  My smallest milling slot cutter is 1.5mm - this is bigger than the 1mm holes I need.  By using the valve plate with pretty near correct sized holes, I could slightly offset the bigger cutter to mill the steam and exhaust ports in the block.  The steam ports are offset 0.25mm to the outsides, and the exhaust port smack bang in the middle.  This leaves a 0.75mm wall between steam ports and exhaust on the block; a bit tight, but it should do:
The ports look a bit crappy in the photo, as there's a lot of burrs.  Some flat-lapping removed those, and things are looking up  :)
That was it for today's work; not a lot to show, but some chips to start off the new year  ;D:
Regards, Arnold
« Last Edit: January 03, 2011, 01:39:08 PM by Brass_Machine »
Re: An experimental engine
« Reply #1 on: January 02, 2011, 05:03:12 PM »
This sounds really interesting Arnold - off to a great start too!  :thumbup: I'll be watching.
« Reply #2 on: January 02, 2011, 05:42:32 PM »
I'm going to enjoy this Arnold nothing like a scratch build to get the crative juices going.
Great start to the project  :clap: :clap: :clap:
How did you work out the spacing for the valve ports ?.
Offline cidrontmg
« Reply #3 on: January 02, 2011, 08:41:18 PM »
Hi Arnold, designing and building a locomotive, even a small one, is lots of work! Once again, I´ll be watching over your shoulder  :)
Olli
Penafiel
Portugal
« Reply #4 on: January 03, 2011, 04:19:14 AM »
Off to a good start Arnold!  :clap:
I'll be watching, quietly.....  :thumbup:
Offline ozzie46
« Reply #5 on: January 03, 2011, 07:45:54 AM »
   OOOH BOOOY another must watch thread.  :D :D
  I'm ready for another swell ride.
  Ron
« Reply #6 on: January 03, 2011, 10:21:21 AM »
Arnold,
Very interesting. Going to follow this one closley since I'm interested in O gauge.
Very nice work so far. Like the CA glue idea. Looks like it works well.
Offline arnoldb
  • Windhoek, Namibia
« Reply #7 on: January 03, 2011, 12:08:57 PM »
Thanks everyone  :beer: - I didn't expect this big a response!
Stew, I used Charlie Dokstader's Valve Gear program and supplied my own dimensions until I got a convenient solution.  It's brilliant stuff to study valve gears, different dimensions and how it all affects engine operation  :thumbup:
Bernd, I can't take the credit for the CA glue idea - but it is very useful.  Just use a known-good quality brand to avoid the problems I had with the cheap $h1t - that bottle's going into reserve to repair hang nails - if it's good for that even; otherwise I'll be vindictive and squirt it out on top of the trash in the wheelie-bin - as a surprise for rummagers...
I'll hold up a bit on this for a week or so; I'll first build some tooling that will make the rest of this project easier  :dremel: - I'll post that up as well to annoy you fellows :coffee:.  Things are a bit hectic at my work; a project that must be finalised by the weekend of the 17th, so shop time might be restricted.  I've learned to stay out of the shop if I'm mentally tired...
 :beer:, Arnold
Offline arnoldb
  • Windhoek, Namibia
« Reply #8 on: January 08, 2011, 04:22:29 PM »
Well, no tooling was made, but a little progress on the project was :)
First things first though...  My 40 year old Myford was still running with its original motor V-belt - it needed replacing badly:
 ::) I forgot to convert its size to "Metric" before I went shopping; just jotted down the imperial size and didn't think to take along the original.  First thing the salesman told me is "We don't sell Imperial v-belts"  ::) So I borrowed his calculator, and got him the "metric" size - well, closest over and under sizes from his stock list & bought both as I couldn't remember if the Myford was closer to its short or long adjustment for the belt.  The longer one works perfectly (even though a certain salesman is convinced a metric V-belt cant work on imperial machinery).  The old girl is running as smooth as I ever heard her - it was time for this belt change and I think I can expect better surface finishes and easier parting off now  :D
On to the project, and first off, I milled 1.5mm wide by 1.5mm deep port holes at the top of the cylinder bores to start the steam passages from:
...tool gloat... - As the port passages needed to be drilled at an angle to meet up with the slots on top of the cylinder, I calculated the angles - 10.8degrees, and brought out my "Christmas Present" - a precision protractor I found in a 2'nd hand shop just before Christmas:
Mitutoyo 187-901 protractor set in mint condition for US$60 - sometimes I get lucky!  :ddb:
I used the protractor to set the valve block at the calculated 10.8 degrees off vertical:
Then used a 1mm center drill to spot a starting hole to drill the steam passage in the milled out bit on the cylinder:
And drilled the steam passage with a 1.3mm drill - checking from the side for break-through into the steam port on the top of the block:
 ::) These macro photos can really light up the minutest imperfections and scratches on a surface!
The steam passages came out OK - with no additional break-through into the cylinder bores, and closely bottoming out in the steam ports on the top of the block:
Looks like a dog's breakfast on close-up - I need to improve my skills.
One problem I found with my design so far is for the exhaust ports.  I need to be able to pipe the exhaust from the cylinder blocks back to the boiler smoke box later on to help create draft there.  On most cylinder designs I've seen so far, the exhaust is in-line with the exhaust port, but I didn't leave enough room, so another angled hole was needed from the port face to where I could fit the exhaust connection pipe.  I decided that I'm not going with a threaded exhaust connection; a Loctite  fit would be fine, as the exhaust side of the engine won't be under pressure, so I drilled a 3.2mm hole 4mm deep into the block from the side to receive the available copper piping I have:
Then I calculated and set the angle to drill the passage hole through from the port face to the exhaust hole.  Made a horrible boo-boo on the first one by drilling the angled passage hole all the way right through to the outside of the cylinder block   :bang: :
Well, Warts & All is what you get :lol:
The second one went better; I remembered to use a bit of rod shoved into the hole and held there to "feel" for break-through into the exhaust hole:
When the drill breaks through into the hole, the bit of rod wiggles.
Photographing down holes is a problem in macro mode... I was hoping to show how the port passage hole was nicely centered in the exhaust hole - if you squint, have a vivid imagination, and take a couple of grains of salt along with that, you might be able to make it out  ::):
On to try and recover the bad port hole.  I first counter bored across both the holes with a 4mm center cutting end mill. A 5mm would have been ideal, but I don't have one, and a 6mm (which I have) is too big, as it would likely break through into the cylinder bore on the one side.  A drill bit would have wandered so I couldn't drill it out:
And a :doh: moment while typing this up...  I could have just counter bored it like I did and then opened up the hole with a 5mm drill afterwards  ::) - too late now!
I then turned down and parted off some aluminium rod (salvaged from an old TV antenna directors :big:) for a press fit into the counter bored hole:
I left the parting pip on - it's useful while handling small bits...
Then with a lavish coating of loctite pressed the slug into the hole with the mill vise.  The pip squashed a bit flat in the process  :lol::
After cleaning off the excess loctite and material from the pressed-in bit, things looked like this:
There's a small artifact left on both sides from the old holes - that's why I would have preferred a bigger hole initially to mend my erroneous ways...
I finished today's shop time by re-drilling the exhaust hole at 3.2mm to depth through the repaired section:
So nothing much for today, and much less pretty, but it _IS_ experimental after all :)
Regards, Arnold
« Reply #9 on: January 08, 2011, 05:13:26 PM »
I just love you're photos and the way you are writing.  :clap:
Keep going.  :nrocks:
« Reply #10 on: January 08, 2011, 05:18:50 PM »
Nice set of cylinders Arnold I'm amazed at their small size.
I've bin shying away from small sizes on a governor I've bin trying to design you've shown what can be done I'll just have to have a new look at it.
The old wiggle wire works a treat don't it  :D
« Reply #11 on: January 08, 2011, 07:04:07 PM »
Arnold those ports look spot on to me, I've never made a slide valve engine yet but have studied and ran through the process in my head many many times!
Good save with the exhaust port, you can't tell. My work has bigger machining marks all over than your 'artifacts'!
Nice work - very intriguing this build!
« Reply #12 on: January 09, 2011, 04:19:17 AM »
Love the way you work/ show Arnold..... Minor warts an all!  :thumbup:
« Reply #13 on: January 09, 2011, 11:25:02 AM »
Agreed. Nice writing makes for good reading. Great thread to follow.
« Reply #14 on: January 09, 2011, 11:47:48 AM »
Nice write up Arnold.
Nice save on that hole. Looking good.  :thumbup:
Offline arnoldb
  • Windhoek, Namibia
« Reply #15 on: January 09, 2011, 02:55:44 PM »
Thanks Benni, Stew, Nick, David, Eric & Bernd  :beer:
Stew, aye - the wiggle wire; just wish I remembered it earlier...  There's a funny thing about the smaller sizes; I think I'm getting used to them.  Now I'll wait for the lads with the funny white jacket  :lol:
Nick, I went with the D valve as I have built one before on Elmer's Grasshopper.  Of all my engines, that one is the easiest and smoothest runner.  In fact, I considered using the same cylinder dimensions for this build, but it would be too large, and scaling would present a couple of problems.  Piston valves was also an option, but they can be leaky by nature and I want to use as much steam as possible on this small scale.
As to the save on the hole; Bogs and many others have shown this type of method used - it's one of those things that can save a lot of time and work, and if done properly is nearly - and in some cases completely - invisible.  On a personal strive to perfection on a home-built project it's a no-no depending on point of view, but when restoring historic pieces or simply saving a complete re-build on an experimental workpiece its always an option.
Today's bit; I had shortened shop time due to a personal commitment that paid off handsomely in a bottle of good single malt   :)
First job was to drill the mounting holes on the sides of the cylinder block - 2.5mm for tapping M3 later:
I drilled out all the mounting holes in the cover plate, valve plate and valve chest stock to 2.1mm by clamping the lot together:
Then on to milling out the valve chests - I got rid of a lot of the excess material by drilling two 6mm holes in each:
And then started milling to the scribed lines with a 4mm end mill.  Apologies for the out of focus photo:
The other chest received the same treatment.  I think I'm due for a new 4mm end mill though - the flutes on this one leaves two "lines" on the sides.
Some may have by this point wondered what I'm going to do about the valve guides and packing glands...  I had decided on doing things a little differently - that's what experimentation is all about - and make up longish press-fit guide & gland combinations, that can be pressed into holes in the valve chest.  As these would be subject to steam pressure and heat eventually, I opted to go for a design where they would be pressed in from the inside of the valve chest with thin flanges to prevent them going out should heat and pressure loosen things.  Seeing the things might be better...
So on to the lathe for a change.  Material for the valve guide combinations is 6mm stainless steel rod, which I turned down to 4.01mm for a length of 8mm, threaded the end M4 for a length of 3mm using the tailstock die holder and then drilled and reamed out to 2mm in the center.  Then I started parting it off leaving a 6mm diameter and 0.2mm thick "flange" on the end:
Then I drilled and reamed 4mm holes in the side of the valve chest:
Pressing the guides in from the inside was a bit daunting.  The bits were coated with some loctite, and then I resorted to using a spanner and hammer to bash them home using the big vise as a guide.  Brute force, and I paid the price by missing a hammer blow - no guesses where that one landed  :doh: :
I should have made a proper pressing jig; would have made for a much better outcome   :bang:
Surprise, surprise...  Things are offset  ::) - the valve ports are offset by 1mm towards the inside, which will become the outside of the cylinders   :palm: :
I'll see how things pan out from here; I'm thinking it will be usable as-is, otherwise I'll have to make a new valve plate.  Now I'm glad I made the valve plate separate from the cylinder blocks.
Time to sample that malt  :beer:
Regards, Arnold
« Reply #16 on: January 09, 2011, 04:35:29 PM »
Shame about the offset Arnold but it looks like there's room to make some offset valves to suit.
Offline arnoldb
  • Windhoek, Namibia
« Reply #17 on: January 15, 2011, 11:50:59 AM »
Thanks Nick - yes, for now I think I can get away with offset valves.  Not ideal though; and I'm actually more disappointed at myself than anything  :coffee:
My IT project's going well at work, so I'll have a bit of time for the shop this weekend   :ddb:
Stole a couple of hours in the shop today, and got down to some bits.
First off, grabbed the M2 taps, and sat down and tapped all the holes on the top of the cylinder using my crude tapping guide and handle.  It looks like one piece in the photo, but actually I set the tap depth in the top "handle" so that it will bottom out the handle on the guide at the correct depth:
 ::) I really need to get around to making a tapping stand...  It will have to be a wee bit more robust than Rob's version though  :lol:
The mounting holes needed to be tapped M3 - but as they are pretty shallow and I want to get maximum depth of thread, I had a bit of a problem; one that seems quite common.  My M3 "final" tap; the last one of the set of 3; has a sharp point:
A quick step to the bench grinder,and with the excess ground off to leave just three threads with taper for engagement in the hole:
Most bolts I've seen will get well down to final depth of thread in a hole tapped with a tap like this; and one could always file that slight taper at the very end of the bolt to go down into a hole completely.
Tapping down to the hole end; on aluminium I just use the second and last taps, and to the top left, you can see my "tapping fluid" for aluminium; ordinary methylated spirits:
And I'm way too lazy to use a tapping guide for M3 - I just free-hand it...
When I looked in my stock for M2 threaded rod, I was all out  ::) - so I  ended up making some from 2mm bronze brazing rod, which is nice and tough to use for studding on lighter-duty applications.  I just start it off clamped in the collet chuck and with the tailstock die holder, and a couple of manual turns by hand to make sure the thread is properly engaged.  Then I power up the lathe on a low speed (on my Myford, surprisingly, lowest non-back gear speed is fine) and hold on to the die holder and let it run through.  It does need quite a lot of tapping fluid to cool things down and lubricate the die, and my left hand is never far away from the lathe clutch in case something goes wrong:
I made up four lengths of rod, and threaded some M2 nuts on - to be used in the next step:
After I took this photo, I ground the excess sharpish points off the rods using the bench grinder; not ideal use of it, but it's very little metal to remove.
Having four separate pieces of threaded rod makes life easier for the next step; a dab of loctite on the tip of each rod, and screw it into the cylinder block until it is finger tight. Then a light additional twist using pliers on the non-threaded bit of each rod, and they tighten up nicely into the block:
A coffee break later - to allow the loctite to cure a bit, and on to the next step.  All the nuts are screwed out to a height where their top end allows adequate space for the valve plate, steam chest, steam chest cover, slightly thicker nuts, and a little extra in case some packing is needed and an allowance for clean-up.  A whole mouthful; but rather too long than too short at this point.  I also dug up my favourite sharp electronics side cutter:
The side cutter trims off the rod quite well, but still deforms the tops and hence threads at the tops slightly:
That is the main reason why I added the nuts in the first place...  Once the nuts are unscrewed, they clean up any thread deformations, allowing nuts to be easily screwed back on again later.   ::) This was REALLY taking the long way around to handing out a handy tip   :lol:
With the cut ends of the threaded rod cleaned up a bit on the bench grinder again, it was easy to screw on the nuts again; hence ensuring that the rods would screw into the block without problems, and the second set of studs was started, and later finished exactly the same as the first lot:
End of work today; the whole lot assembled and some rods shoved in the valve holes:
I took that lot inside together with the bit of copper pipe that will most likely become the boiler, and compared sizes against Fred the loco:
It's nice to start getting a visual comparison and while the previous two photos don't mean too much, it does start to give me an idea of what's needed from the frames, which will be up next.  Some Thinking is required   :med:
Regards, Arnold
« Reply #18 on: January 15, 2011, 02:54:57 PM »
Comming along well Arnold  :thumbup:
Is O gauge 13/4" between the tracks ?
Offline Gerhard Olivier
« Reply #19 on: January 16, 2011, 01:20:35 PM »
Nice progress Arnold  :beer:
Keep it coming
Gerhard
Guernsey
Channel Islands
Offline arnoldb
  • Windhoek, Namibia
« Reply #20 on: January 16, 2011, 03:05:47 PM »
Stew, thanks  :).  O gauge is 32mm or 1 1/4" between the tracks.  1 3/4 (45mm) is gauge 1 - which I wish I went for when I started off with the small locos.  This loco will end up as a 16mm narrow gauge (well, very approximate) scale  :lol:
Thanks Gerhard  :beer: - I'll try to - though I've hit a snag that will slow things down a bit.
Yesterday evening when I started drawing up the frames I realised that some of the valve-gear components and the front wheel wanted to occupy the same space which is a physical near-impossibility, so today I spent re-designing the entire valve-gear and running simulations to get acceptable and near equal cut-off's for both forward and reverse gear settings, with measurements that actually make sense.  I'm getting more and more respect for the engineers at the turn of the last century!
I think I'll spend some time drawing up the frame and gear parts in CAD first - which might take a while, as I'm a bit slow with that  :palm:
 :beer:, Arnold
« Reply #21 on: January 17, 2011, 08:06:45 AM »
You're right, bet it's a fair job to design it so everything fits in there. Very challenging project this is but you'll get there.   :bow:
Offline arnoldb
  • Windhoek, Namibia
« Reply #22 on: January 26, 2011, 12:27:42 PM »
Thanks Nick  :beer: - yes, it's a big challenge on a small scale... I'm sure I'll lose some battles along the way, but definitely not the war; I'm much too obstinate to allow that  :lol:
This project has been waylaid a bit; I wanted to be much further along but the redesign and personal life interfered.
Re-designing the valve gear layout took quite a bit of time, but I think I'm close enough to continue now.
Today's bit - a start on the frames...
As the loco will be a bit on the narrow side, I want the frames to be fairly heavy to keep the centre of gravity as low as possible.  I decided on using 3mm thick steel plate for the sides, and will use mild steel for the cross beams as well.  The only 3mm plate I have is locked up in a fairly big sheet, and cutting a strip off it was a bit of a challenge.  I could have tried man-handling it on the band saw, but that was just asking for a broken blade.  Another option was using one of my angle grinders, but I don't like cutting thinnish plate with either of them; it takes a lot of concentration and makes a hell of a noise.  Gas is a bit expensive, so I tend not to use my oxy-butane kit for cutting.  So, I settled on the venerable jig saw with a suitable fine HSS blade for cutting thin steel:
Next I sawed of two suitable lengths from the strip and off to the drill press with a rubber-backed sanding pad mounted in it.  After a bit of work, most of the rust and crud was gone from the plates:
A bit of clean-up followed on the mill; very carefully over the extended bits with a fine feed:
In retrospect, it would have been MUCH better to clamp the frames to a suitable length of thickish bar before clamping in the mill vise for that job!
Once I had both long sides parallel and to width, I squared up one reference edge as well:
Then I drilled holes for the cylinder mountings, axle bushes and valve gear mountings/bushes:
No lay-out; just coordinate drilled from the reference corner by using the mill's graduations.
Some holes followed for mounting the cross beams, and I finally split the two sides apart, de-burred and left off for the day:
There's still some more work to do on the frames, but at a later point - for now they are where I need them.
Regards, Arnold
« Reply #23 on: January 26, 2011, 02:26:32 PM »
Hi Arnold
This is the second time you have shown rusty steel in your posts  :scratch:  ,,, do you have it imported like that ,,,, as you have 12 months of sun , and an average annual  rain fall on 0.001" ,,, sorry your metric 0.025 mm  :lol: :lol: :lol: :lol: :poke: :poke: :poke: :D
Looking good mate
Rob  :D
Offline arnoldb
  • Windhoek, Namibia
« Reply #24 on: January 27, 2011, 11:09:16 AM »
 :lol: :lol: Thanks mate  :beer:
All the rusted bits are from being a cheapskate skip-diver  :doh: - and generally just getting my hands on what I can find lying around scrap.  I don't know what's up with the weather here this year though; had more than 250mm of rain in the last 2 weeks  :scratch: - that's about what we get in a year.  Don't like it... Makes tools rust and hides the sun  :loco:
 :beer:, Arnold
