Author Topic: Almost to late for a stocking stuffer  (Read 5316 times)
Offline PTsideshow
« on: December 22, 2010, 04:49:56 PM »
A neat Idea, and a possible use for all those worn out hex shaft bits in the tool box, Even if you buy the adapter and weld the bits to every thing else. It would be of use on some jobs. I don't know about scrubbing or brushing other than small area.
You could also make the adapter with some old worn out blade ends and a drill motor drive adapter! :dremel:
Reciprotools
 :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
