Author Topic: Co-axial indicator?  (Read 13745 times)
Allthumbz
Co-axial indicator?
« on: November 13, 2010, 06:10:25 PM »
How is a co-axial indicator used on a lathe?
Thanks.
Offline Powder Keg
  • Machinist Extraordinaire
Re: Co-axial indicator?
« Reply #1 on: November 13, 2010, 06:37:36 PM »
They are mainly used on a mill to swipe in a bore or OD. The only thing I can think of on a lathe would be to check the tail stock alignment? But I've never done it.
Wesley P
« Reply #2 on: November 14, 2010, 02:36:46 AM »
The one I've got came supplied with a pointed stylus that you can locate in a centre pop, I guess you can hold the indicator in your tail stop locate the stylus in a centre popped bit of work held in the four jaw, then move the jaws so that the indicator show that the pop is running true, so you can machine a hole accurate positioned on the pop.
Offline kwackers
« Reply #3 on: November 15, 2010, 09:15:39 AM »
I'd assume you centre a piece of bar in the chuck (or take a skim off to get it perfect), fit the co-ax indicator in the tailstock and adjust for minimum wobble?
« Reply #4 on: November 15, 2010, 10:14:02 AM »
Actually, the rotating part of the coax has to be in the chuck with its probe rotating around the tail stock ram (or a round reference (centre) in the tail stock). It could also be used to zero-in a drill or ream mounted on the tool post.
One thing I've over looked in my MkI design was a spring to allow it to operate horizontally (ATM it relies on gravity).
Offline kwackers
« Reply #5 on: November 15, 2010, 10:17:43 AM »
Ah yes...
I did consider the spring thing on your design, I figured it might be possible to have another bearing on the far side with a spring loaded grub screw, would that work?
« Reply #6 on: November 15, 2010, 10:44:57 AM »
Ah Yes, good idea :) And, it would pre-load the axial bearing solving any off-centre wobble (as suggested by Richard)
