Author Topic: Mill  (Read 22962 times)
Offline BK
Mill
« on: November 07, 2010, 04:51:31 PM »
I just bought myself a mill, it's a Hafco HM 30 (ya China) 3 yrs old and done little work.
http://i160.photobucket.com/albums/t184/oldcranker/100_3595.jpgMill
It came with a LOT of extras like a 12" rotary table.
http://i160.photobucket.com/albums/t184/oldcranker/100_3596.jpgMill
5" HD swivel vice
http://i160.photobucket.com/albums/t184/oldcranker/100_3597.jpgMill
3 1/2" tilting vice
http://i160.photobucket.com/albums/t184/oldcranker/100_3598.jpgMill
2 sets of holddowns.
http://i160.photobucket.com/albums/t184/oldcranker/100_3600.jpgMill
A set of collets and end mills plus a 70mm flycutter
http://i160.photobucket.com/albums/t184/oldcranker/100_3601.jpgMill
Plus a box of Alum billets
http://i160.photobucket.com/albums/t184/oldcranker/100_3599.jpgMill
I'm happy with my "haul" to buy the extras new would cost more then I paid for the whole lot.  :D
If it aint broke, don't fix it!
Re: Mill
« Reply #1 on: November 07, 2010, 05:12:10 PM »
Nice haul :)
They're actually very useful machines - my one is a Taiwanese NuTool version. It was knackered when I got it so have been modifying it at every opportunity (see http://billtodd.dyndns.org/drillmill)
Re: Mill
« Reply #2 on: November 07, 2010, 05:33:54 PM »
Nice haul!
Offline Jonny
Re: Mill
« Reply #3 on: November 07, 2010, 08:46:26 PM »
Good buy i thinks thats known as the RF30 over here, i have the equivalent of the RF25 doing very little.
Leadscrew nuts are a bit naff mine broke within two years so did the motor mid job.
The only thing that spoils them is the round column.
Re: Mill
« Reply #4 on: November 08, 2010, 02:26:59 AM »
Bernie.
That's a great starter pack. Yer off to a flier there!   :clap:
BIG learning curve ahead........ Enjoy!  :thumbup:
Offline BK
Re: Mill
« Reply #5 on: November 08, 2010, 03:53:34 AM »
Hi David, been 2 days setting it up but this arvo I made chips.  :)
It seems a very solid machine (very big too), just a matter of working out speeds, how to hold work down, how to, how to , how to, how to, :bugeye:  :jaw:  :lol:  :bang:
Re: Mill
« Reply #6 on: November 08, 2010, 04:06:21 AM »
Bernie.
If yer don't already know.......
Find out what climb milling is, and DON'T DO IT!  :bugeye:
     :thumbup:
Offline Pete49
Re: Mill
« Reply #7 on: November 08, 2010, 05:44:38 AM »
nice haul though that ali is dangerous to your health so being old and caring send it to me and I will dispose of it for you
cheers
Offline BK
Re: Mill
« Reply #8 on: November 08, 2010, 06:22:34 AM »
Bernie.
     :thumbup:
Yep, my younger brother has an old mill, been told thanks David.
Re: Mill
« Reply #9 on: November 08, 2010, 07:11:42 AM »
Bernie.
     :thumbup:
Actually, if you sort the nuts out and clamp the head tight, the machine is just about rigid enough to cope with light cuts.
As a quick fix, I cut the nuts across the split, faced the cut ends and reassembled thus...
Offline Bogstandard
  • Bogs Group
Re: Mill
« Reply #10 on: November 13, 2010, 10:58:56 AM »
Be very careful with the quill on these machines. It WILL drop when you least expect it and take a gouge out of your job.
Make sure it is physically pushed DOWN before you tighten up the quill lock, and this needs to be done between cuts.
There are a few mods about to cure this problem, and they usually concern a weight and a pulley to counteract the weight of the quill, so effectively pulling it UP all the time.
Just be careful.
Location - Crewe, Cheshire
Skype - bandit175
Re: Mill
« Reply #11 on: November 13, 2010, 02:20:37 PM »
As Bogs has pointed out the quill dose drop on these machines ,giving a poor finish when boring and worse if you are doing an intermittent cut ,say cutting a radius on cylinder saddle using a boring head and down feeding the quill.
The cutter will move up as it comes in contact with the work and drop as it leaves  :bang:
So the quill needs to be loaded up so that it is always in contact with the quill feed pinion.
Mods done to my RF25 MILL/DRILL ,,,spring attached to collar  on quill ,fed up through the head casting and secured to the belt guard ..  Sorted .
Got rid of the two nuts that lock the head , fitted two levers ,,,Replaced the small lever that locks the belt tensioner with a T bar ,,, and fitted lever to motor mount plate to make belt tensioning easier.
Offline Bogstandard
  • Bogs Group
Re: Mill
« Reply #12 on: November 13, 2010, 02:43:07 PM »
I haven't seen it done that way Rob, nice one.
I forgot to mention in my last post, if you do such a mod as Rob has done, there is no need to do what I said in the first part, about making sure the quill was fully down.
Skype - bandit175
Offline Jonny
Re: Mill
« Reply #13 on: November 13, 2010, 07:16:42 PM »
Its been 6 years since ive used mine but i cannot honestly recall seeing the quill drop in over 4 years.
Reason i always put tension on with the quill lock when winding the Z feed. If a heavy cut i will tighten up the quill before putting a cut on.
