Author Topic: Building a Quick Change Gear Bow, need help.  (Read 7874 times)
Offline boxcarmj
« on: September 30, 2010, 12:07:07 AM »
Is there a relationship between the spindle gear (40T) and the leadsrcrew (12TPI)? Is there a formula I need to work out? Thank-you Mike.
Re: Building a Quick Change Gear Bow, need help.
« Reply #1 on: September 30, 2010, 04:11:48 AM »
Yes that ratio is what makes the threads.
You have a 12 tpi leadscrew and 40 T spindle gear, if you fit a 40T to the leadscrew it will cut 12 tpi as it's a 1:1 ratio
Fit an 80T and it now cuts 24 tpi as it's slowed down by a 2:1 ratio
In a straight drive train, i.e. just one row of gears any idlers in the middle run don't count as they cancel out.
John S.
Offline boxcarmj
« Reply #2 on: September 30, 2010, 09:46:05 AM »
Thank-you John.
