Author Topic: Adapting Car Brakes  (Read 11470 times)
Adapting Car Brakes
« on: September 24, 2010, 04:55:12 AM »
I've not posted anything for a while so thought I might put this up for your amusement.
I made some spigot spacers for my Vectra disks which are bigger diameter than the standard Astra ones at 288mm. They also have a larger centre hole than the standard Astra disks. Hence the spacers.
So I chopped a length of 70mm dia from a larger bar and stuck it in the lathe.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5524.jpgAdapting Car Brakes
Cleaned it up and drilled a hole on the centre with the biggest drill bit I have.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5525.jpgAdapting Car Brakes
Bored the centre hole out to match the Astra hub. (this takes a while and would be better to start with a pipe, but gotta use what's at hand. Well that's what machines are for ....!)
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5526.jpgAdapting Car Brakes
Then parted off several pieces. The brake disk is 7mm thick so I made the spacers 6mm to make sure they didn't foul the wheel fitting.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5527.jpgAdapting Car Brakes
Chamfered all the inner and outer edges to clean them up.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5529.jpgAdapting Car Brakes
And here we are, well if you're gonna make a pair may as well make some more at the same time :Banane44:
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5531.jpgAdapting Car Brakes
Fits the disk nicely
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5532.jpgAdapting Car Brakes
And here we are fitted to the hub ... nice snug fit ....
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5534.jpgAdapting Car Brakes
Next job is to drill the disks to four stud ...
« Last Edit: September 24, 2010, 05:02:39 AM by Darren »
Re: Adapting Car Brakes
« Reply #1 on: September 24, 2010, 04:56:50 AM »
Now to sort the bigger disks out.
Set-up the milling machine so that I could make four new holes at 100mm PCD and at 90deg to each other. I don't really like disturbing the mill as it takes ages to line it up true afterwards. But I couldn't do this vertically so horizontal she had to go!
I'm using the drill bit just to line things up on the old disk. The holes were cut using a milling cutter as one hole is elongated. Try that with a drill bit and you'd be in trouble !! Once you have one hole lined up then it's just a matter changing disks and rotating the dividing head 90deg each time.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5537.jpgAdapting Car Brakes
Here I'm counter sinking the little 6mm disk retainer screw hole.
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5542.jpgAdapting Car Brakes
All fits nicely, done both sides so that's that job done ..
http://i401.photobucket.com/albums/pp92/thebodger/Astra/Its%20Back/IMG_5541.jpgAdapting Car Brakes
« Reply #2 on: September 24, 2010, 10:17:28 AM »
The car stuff is more than welcome here. I love to see what people are doing with their cages.
How's the fit? Will you have to use a different caliper or make a spacer for your current setup?
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #3 on: September 24, 2010, 10:34:34 AM »
What Eric said :ddb: I haven't seen anyone tip a mill head for a long time. That's what their for. When I was going to school, the instructors would go around and tip the heads. That got you familiar with tramming them in.
Nice Job Daren!!!
Wesley P
« Reply #4 on: September 24, 2010, 11:32:00 AM »
Ahem!
http://madmodder.net/index.php?topic=2726.msg31100#msg31100
Ok, I grant you, that is quite a long time ago now....  :doh:  :poke:
« Reply #5 on: September 24, 2010, 12:22:18 PM »
That centre pic...... It was beginning to look like an old Swiss cheese!  :lol:
Nicely done Darren!  :thumbup:
« Reply #6 on: September 24, 2010, 12:29:09 PM »
Ade,
With those brakes as rusty as they are, the first time you use the brakes I can see the car lifting it's tail end into the air as the front wheels screech it to a halt.  :lol:   :lol:
Kinda' like using the front brakes on a bicycle. :coffee: Ask me how I know? Nah, never mind.  :lol:
BTW, like Eric said, nice to see some auto work being done. I'm sort of the machining guy to go to in our community car club. So seeing the way your fixing things helps a lot. Thanks for taking the time out of a busy schedule you have between work and sleep.
