Author Topic: Small moving steady  (Read 12714 times)
Small moving steady
« on: July 07, 2010, 02:06:59 PM »
An old work friend ask if I could do a little job for him, but the job needs a 4 " length of 4.5 mm dia bar all I've got is 3/16".
But with this bit of kit skimming the bar down is a synch.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4074.jpgSmall moving steady
I picked it up from Chornos a few years ago and found it very handy.
First make a brass bush the same dia as the starting bar in this case 3/16
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4072.jpgSmall moving steady
Then turn a short length of the bar down to the required dia 4.5 mm
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4064.jpgSmall moving steady
Then use this as a set piece to set the tool on dia.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4076.jpgSmall moving steady
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4077.jpgSmall moving steady
Then with just a short length sticking out of the chuck, use this to centre and square the steady.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4080.jpgSmall moving steady
Then wind the tool away from the chuck and pull the bar out and insert the end into the bush.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4081.jpgSmall moving steady
With just a spot of oil on the bush start the machine enguage feed and reduce the dia of the bar.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4082.jpgSmall moving steady
Thats it job done in about 10 min.
http://i431.photobucket.com/albums/qq32/sbwhart/Reducing%20Dia%20of%20a%20thin%20bar/100_4083.jpgSmall moving steady
Re: Small moving steady
« Reply #1 on: July 07, 2010, 02:23:30 PM »
Now..... That`s a handy little weapon!  :headbang:
Well shown Stew!  :thumbup:
Offline jim
« Reply #2 on: July 07, 2010, 03:36:17 PM »
that's quite impressive!
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #3 on: July 07, 2010, 11:42:17 PM »
What a very good tool, Stew.  Thanks for the introduction!
Dean
Dean W.
Shop Projects:
« Reply #4 on: July 08, 2010, 09:25:27 AM »
I've seen or read about that method somewere before. Had forgotten about it.
Nice job of showing the set up Stew.  :thumbup:
Bet it took longer to do all that work of pic taking and posting.  :lol:  :lol:
But again thanks for taking the time to show how to solve a simple problem.  :proj:  :ddb:
