Author Topic: So the potter said can you buy this stuff?  (Read 34333 times)
Offline PTsideshow
« on: June 27, 2010, 02:54:44 PM »
Ok here are two pic's and a quickie!
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/DSCF9865-1.jpgSo the potter said can you buy this stuff?
A ceramist,potter's clay workers hand turn table. made from aluminum and I have seen one from magnesium. They can be found at garages sales, school surplus inventory sales etc.
They generally have a steel point shaft with a press fit ball bearing in the very end. This one and the other ones I have were tight in the socket. Some penetrating oil and some turns and then a clean up works wonders.
I use the for a lot of things you can see there are 3 screw holes in the base you can flip it upside down and screw a plywood section to it so you can hold larger items on it.
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/DSCF9867.jpgSo the potter said can you buy this stuff?
Here I'm using it as a paint turntable painting another item that I will post in this section as soon as they are finished. More repurposing of obsolete wheel rims. :dremel:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: So the potter said can you buy this stuff?
« Reply #1 on: June 28, 2010, 12:10:01 PM »
Thats a neat idea. I like that...
Baldrocker
« Reply #2 on: June 28, 2010, 09:13:43 PM »
OOOOOOh
br :clap:
