Author Topic: Measuring Temperature  (Read 46492 times)
« on: May 25, 2010, 05:12:46 PM »
Hi Lads a spot of help needed
I need some way of measuring the temperature in a temporary core oven i am going to knock up ,,250C max ,,,,,,,,, I saw some were a set up with a multi meter and two wire wound together   :scratch:,,, any idea what type of wire ?  and how do you calibrate it ?  . or dose anyone have a better idea
Thanks Rob
Re: Measuring Temperature
« Reply #1 on: May 25, 2010, 05:29:47 PM »
There are a number of ways of measuring temp...
Optical pyrometer..( I guess you aint got one to hand....) or there is the simple thermocouple...
A thermocouple is made by twisting together two disimmilar metal wires ( Iron/Constantan) that will generate an emf proportional to temperature...( Its called the Seebeck effect...  I'm a tiffy by trade..)
A standard dvm from Maplins should suffice for measuring the voltage 'though you may need tables to convert from volts to degrees( unlesse the dvm has a t/c input..! )
Have a look here: http://www.tc.co.uk/ I use this company at work, let me know if you have any queries. :thumbup:
« Last Edit: May 25, 2010, 05:33:01 PM by John Rudd »
« Reply #2 on: May 25, 2010, 05:34:01 PM »
I got one of these  .. or similar  .. comes with a (type K ??) thermocouple
http://www.rapidonline.com/Tools-Fasteners-Production-Equipment/Test-Equipment/Multimeters/328-Digital-LCD-multimeter/31051
Up to circa 900 c IIRC
Will look if interested ..
Quite surprised how accurate it was .. about +/- 6 C at 800 C   Checked by a mate in the test labs @ RR
Dave BC
OOOps EDIT ... spec says type K  .. memory not so shot as I thought  ... Hope yet .. :lol:
« Last Edit: May 25, 2010, 05:37:04 PM by Bluechip »
« Reply #3 on: May 25, 2010, 05:59:32 PM »
No response from Rob yet !!!
Not gone down another hole has he .... :lol:  :lol:
« Reply #4 on: May 25, 2010, 06:14:36 PM »
Could well be ..
Did notice a puff of smoke ....
I, too,  shall retire ...
Dave BC
« Reply #5 on: May 25, 2010, 06:52:01 PM »
...could the voltage not be linked to a PIC microcontroller and converted to the temperature. Would be a nice project there Rob, you said you fancied trying your hand at PICs when I met you earlier in the year!
« Reply #6 on: May 25, 2010, 08:09:55 PM »
Rob, have a look at this:
http://www.johnlewis.com/230335010/Product.aspx
Seems to go up to 320C. At that price, is it worth trying to make your own?
On the KISS principle, rather than building an oven, could you get permission to use the one in the kitchen? The thermometer might still be a good idea though, as oven thermostats can be rather approximate.
« Reply #7 on: May 26, 2010, 02:01:22 AM »
Thanks lads  :bow: :bow: :bow:
Lots of top ideas  :thumbup:
John ,, Whats a tiffy ?  :scratch:  ,,,,Seebeck effect  :smart:
Dave  :lol: :lol: :lol: :lol:  i needed my beauty sleep  :lol: :lol: :lol:
Hi Chris ,,,,,,,That one for the future  :dremel:, i am saving electronics for winter projects ,when the shops too cold
Hi Andy ,, now why did i not think of that   :clap:  could be the way to go , as this is oven is just a quick knock up job ,, until i can sort out something more permanent for core drying .
The plan was to use the kitchen oven , thats what i normally use ,,,,,,,,,,but the cores for the engine i am working on dont fit   :bang: :bang: :bang:
Thanks Rob  :thumbup:
« Reply #8 on: May 26, 2010, 03:33:04 AM »
Not so easy ... output is non-linear ... gruesome ...
Once had a large book about various sensors etc. including thermocouples. Absolutely crawling with narky maths ...here is a quick overview ..
http://en.wikipedia.org/wiki/Thermocouple#Voltage.E2.80.93temperature_relationship
EDIT  'Owd on ... looks like a set of calibration tables here
http://www.temperatures.com/tctables.html
Maybe quite do-able if you need a look-up table in the PIC   :thumbup:
Apologies for my pessimism
Dave BC
« Last Edit: May 26, 2010, 03:53:35 AM by Bluechip »
« Reply #9 on: May 26, 2010, 04:07:34 AM »
Why beat yourself about the head doing it in a PIC, when it's already been done with an Arduino, and with some nice'n'easy code no less?
In fact, I did one my very self, for measuring exhaust gas temperature, I did a bit of a writeup here: http://www.microcogen.info/index.php?topic=927.0
The code was only a few lines long, its main task was to read the output from the little black chip (that was the hardest bit of the whole task, soldering that little bugger to a DIP socket...) & send it out over the serial port. I can post the code here if anyone's interested.
I bought a fairly expensive thermocouple that's good for 1100 degrees, there are cheaper ones which don't go so high.
« Reply #10 on: May 26, 2010, 07:15:03 AM »
Tiffy...An instrument artificer (  I served my time at ICI..)
The Seebeck effect was discovered by a German dude, its the conversion of temperature difference into voltage (millivolts in this case..)
Offline SKIPRAT
  • Gainsborough Lincolnshire England
« Reply #11 on: May 26, 2010, 09:39:09 AM »
Hi All
I would cheat and use this it followed me home from a local car boot sale about a couple of years ago it comes in handy now and again i shall have to get a ceramic enclosed thermocouple to use it to its maximum temp though!
http://i998.photobucket.com/albums/af106/g6fow/Temp1.jpgMeasuring Temperature
http://i998.photobucket.com/albums/af106/g6fow/Temp2.jpgMeasuring Temperature
Cheers Paul   :beer:   :beer:
One Mans Junk Is Another Man's Treasure G6FOW
