Author Topic: LED Light for X2 Mill (Project Completed)  (Read 31757 times)
Offline 75Plus
« on: May 10, 2010, 08:21:38 PM »
I recently posted a thread about mounting an umbrella light on an X2 mill. That light worked fine when using the drill chuck and end mill holders to hold the tool bits. When I switched to using R-8 collets to hold the tool bits I found that  this light was just too large to allow a clear view of the work piece. At that point I started thinking about plan "B".
In my scrap box I found a 3" nylon wheel that was 3/4" wide. This will be the body of the plan "B" light. I also have a bit of circuit board material and a some 1/4" thick Lexan. In a departure from the way I usually do things I decided draw up the project first, then make it. I found some high output LED's and placed the order. While I am waiting for them I drew the major components.
Starting with the body here is the top view:
http://i944.photobucket.com/albums/ad289/AlveyJoe/20LEDBody_1.jpgLED Light for X2 Mill (Project Completed)
Since my RT moved 9 degrees per revolution of the hand wheel I decided on 20 LED's on 18 degree centers. This way I won't have to do any extra calculations. The holes will be drilled with a #8 (.199") drill which is a snug fit for a 5mm LED. The cavity is .435" deep and .500" wide. The circuit board will be recessed into the body so there is a ledge provided to support it. This view shows the details.
http://i944.photobucket.com/albums/ad289/AlveyJoe/20LEDBody_2.jpgLED Light for X2 Mill (Project Completed)
Here is the bottom view. I will be adding a counter sink to each hole to allow more exposure for the light.
http://i944.photobucket.com/albums/ad289/AlveyJoe/20LEDBody_3.jpgLED Light for X2 Mill (Project Completed)
Here is the circuit board with details added.
http://i944.photobucket.com/albums/ad289/AlveyJoe/20LEDCirBrd.jpgLED Light for X2 Mill (Project Completed)
And here is the top cover /swarf guard.
http://i944.photobucket.com/albums/ad289/AlveyJoe/20LEDSwarfGd.jpgLED Light for X2 Mill (Project Completed)
The mounting adapter was described in this thread.
http://madmodder.net/index.php?topic=3017.0
I will be making swarf as soon as the LED's arrive. Stay tuned.
« Last Edit: December 06, 2010, 10:01:17 AM by 75Plus »
Re: LED Light for X2 Mill
« Reply #1 on: May 10, 2010, 09:13:16 PM »
Nice design there Joe.
It's fun modding something like that. What are you going to use for a power supply? The orginal one that came with the first light?
Offline 75Plus
« Reply #2 on: May 13, 2010, 09:53:06 PM »
It's fun modding something like that. What are you going to use for a power supply? The original one that came with the first light?
Sorry about the delay but I have been on another project.
I will be using a surplus cell phone charger. It is a switching type power supply that is rated 4.6v and 1 amp output. According to my digital VOM the 20 LED's and the dropping resistor draw a total of 186 410 ma. The circuit board will be mounted in an enclosure and attached to the motor controller enclosure. I have just about finished the project and will add more info and pictures in the next few days.
Edit: Current draw in error. I was on the wrong scale. The actual current is 410 ma.
« Last Edit: May 14, 2010, 01:21:00 PM by 75Plus »
Offline 75Plus
« Reply #3 on: May 20, 2010, 09:17:11 PM »
From the lack of replies this is not exactly a HOT topic but I started it and I will finish it.
After some consideration I decided to use the mill to do most of the machine work. Once I had it on the RT I was able to mill the cavity, drill the holes for the LED's and drill the circuit board all with one set up.
Here I am milling the cavity.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2421.jpgLED Light for X2 Mill (Project Completed)
Cavity complete.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2423.jpgLED Light for X2 Mill (Project Completed)
Drilling the holes.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2427.jpgLED Light for X2 Mill (Project Completed)
Circuit board ready for drilling. I used the point of center drill to peel a path in the copper to create the circuit board.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2430.jpgLED Light for X2 Mill (Project Completed)
The holes for the leads were drilled with a # 67 drill. The spacing is .100" so I shifted .050", drilled 20 holes then shifted .100" and repeated the drilling.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2434.jpgLED Light for X2 Mill (Project Completed)
This is a shot of beginning the assembly.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2420.jpgLED Light for X2 Mill (Project Completed)
The power supply. It was once a charger for a cell phone. The output is 4.4 VDC which is near the 3.6 volt forward drop I needed for the LED's. To set the current at 20 ma. required a 2 ohm resistor. After two hours of use there was no detectable heating. I mounted the power supply in a mini enclosure that was then attached to the bottom of motor control enclosure.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2440.jpgLED Light for X2 Mill (Project Completed)
I mounted the current limiting resistor on a four point terminal strip which I stuck to the side of the motor control enclosure. The AC to supply the power supply was picked up at the terminal strip that supplies the cooling fan transformer. The light comes on when the fan does.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2443.jpgLED Light for X2 Mill (Project Completed)
Here is the light mounted around the spindle. It allows a clear view of the work piece.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2444.jpgLED Light for X2 Mill (Project Completed)
This shot was taken at night with no other light on in the shop.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2394.jpgLED Light for X2 Mill (Project Completed)
Since I had much of the material on hand (the nylon wheel for nearly 20 years) the total cost was a huge $11.80.
I am very pleased with the outcome of this little priject.
Re: LED Light for X2 Mill (Project Completed)
« Reply #4 on: May 20, 2010, 11:33:59 PM »
This has turned out to be a very nice light. Judging by the one photo that you showed with it as the only light it should certainly light up what ever you are working at on the mill.
Even though you don't have a lot of replies Joe there have been 170 people that have read it and everyone has probably taken something from it to file away for sometime when they need a light like Joe made.  :doh:
Thanks for finishing what you started Joe, I like people like that.  :ddb: :ddb:
« Reply #5 on: May 21, 2010, 02:09:57 AM »
Joe,
Very nicely done, and shown.....  :clap:
Like many projects electronic/ electrical, I was watching quietly, in awe!  :bow:
I have had a vague idea to use one of those patio parasol/ table ring lights......
Thank you!  :thumbup:
« Last Edit: May 21, 2010, 02:12:35 AM by Stilldrillin »
« Reply #6 on: May 21, 2010, 05:08:30 AM »
Nice job, Joe. I've been watching too, and mean to sort out something similar myself.
I recently bought (from B&Q at under a fiver each, for those in the UK) a couple of these:
http://i689.photobucket.com/albums/vv257/andyf1108/Ledlights/BQledlight.jpgLED Light for X2 Mill (Project Completed)
which give a good bright light. I'm thinking of cannibalising the 24 leds out of one, then following in your footsteps. Unless a suitably sized bit of PCB comes to light (no pun intended) I may just use a couple of rings of bare copper wire, one for the led anodes and another for the cathodes. The lamps run on 3 AAA cells, giving 4.5V. That drops to around 3.6V when switched on, so I'll need to hunt through my ever-growing collection of discarded wall warts for something in that region which can push out around half an amp.
« Reply #7 on: May 21, 2010, 06:34:34 AM »
I`ve got one of those lamps Andy!
A very handy light. It`s magnet sticks it under the gearbox, behind the mill spindle.  :thumbup:
BUT! The magnet attracts steel swarf....
Offline 75Plus
« Reply #8 on: May 21, 2010, 09:47:30 AM »
Andy and others, the LED's in the battery powered lights are wired in parallel due to the supply voltage being low. Any number of LED's can be paralleled and supplied with a wide range of voltages by using a suitable limiting resistor. Here is a resistor calculator that figures it all out for you.
http://ledz.com/?p=zz.led.resistor.calculator
The picture I posted as "the mill light only" was from the original umbrella light that was too large. Here is one from the new light. Sorry for the error.
http://i944.photobucket.com/albums/ad289/AlveyJoe/Mill%20Light/100_2456.jpgLED Light for X2 Mill (Project Completed)
« Reply #9 on: May 21, 2010, 10:22:46 AM »
Thanks for the link, Joe. My bucket of old wall warts hasn't yielded anything with volts in single figures and capable of >500mA, but there's a 15V, 750mA one. So I'll complicate an otherwise simple task by wiring chains of 4 leds in series, to give 6 chains, then wire the chains in parallel and select a resistor on test (otherwise known as trial and error), starting high and working down to lower resistances until I get enough, but not too much, light.
Or I could fiddle about with Ohm's Law. I think I can remember it: An ohm is an 'ouse where a volt lives  :)
Offline Sic Semper Tyrannis
« Reply #10 on: November 02, 2011, 08:29:09 AM »
Yeah I know it is a "thread from the dead", but check these light rings out...
http://www.ebay.com/sch/i.html?_nkw=headlight+ring&_sacat=22689&_odkw=&_osacat=22689&_trksid=p3286.c0.m270.l1313
Cheap for a pair, 12volts.
May get some to play with on the mill.
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
« Reply #11 on: November 02, 2011, 08:53:08 AM »
Nice thinking  :clap:
_________________________
Greetings / Benni
Offline Fredbare
  • Fakenham, Norfolk
« Reply #12 on: November 02, 2011, 10:36:54 AM »
Well done and well presented, certainly had my interest.
Johnhttp://madmodder.net/Smileys/default/happy0065.gif
Offline Pelallito
« Reply #13 on: January 17, 2012, 07:53:43 AM »
I just found your post and liked it a lot! :thumbup:
I don't know anything about LED lights and very little about electronics,  :zap:, but you gave me the urge of attempting to make something like it.
There are many of us here that need all of the light we can get on a project, the eyes just don't work like they use too. :bang:
Thanks for the post.
Fred
« Last Edit: January 17, 2012, 03:56:42 PM by dsquire »
