Author Topic: Where can I get these from  (Read 13595 times)
« on: April 12, 2010, 12:21:40 PM »
Can any one point me in the direction of these screws
No.8 ANF (American National Fine) semi - countersunk head, allen cap screw
O/D    =    0.162"
Core    =    0.130"
Pitch    =    0.0277
Overall length 8mm, but a little longer would not go amiss as they could always be cut down to size.
Re: Where can I get these from
« Reply #1 on: April 12, 2010, 12:37:03 PM »
The figures here
http://homepages.tesco.net/~A10bsa/unfgo.htm
for no. 8 UNF are 36tpi/0.164" pitch, major 0.164", minor (for external threads) 0.1299", which is effectively the same. "UNF" might cause less headscratching than "ANF" here in the UK, but I've no idea where you might get them, particularly with such special heads.
PS 36 tpi = 0.705mm pitch. An M4 thread has a pitch of 0.700mm, which is probably near enough. For the major diameter, 4mm = 0.157", which is about 7 thou undersize for an existing No 8 ANF/UNF threaded hole. The minor diameter is similarly undersize. Might M4 be sufficiently close to give a reasonable fit?
« Last Edit: April 12, 2010, 12:49:44 PM by andyf »
« Reply #2 on: April 13, 2010, 01:46:48 AM »
Thanks for the info Andy I'll give it a try.
Offline HS93
« Reply #3 on: April 13, 2010, 03:02:19 AM »
Pop an email to this chap he can someimes help and is very fast cheap and so is the delivery so small orders are not going to cost the earth , he may be able to help, he did when I wanted some stange bolts
 http://www.modelfixings.co.uk/cap_screws.htm
Peter
« Reply #4 on: April 13, 2010, 07:07:04 AM »
Yup, another vote for Modelfixings...Quick delivery and excellent service/choice. Well worth asking them....
« Reply #5 on: April 14, 2010, 10:35:56 PM »
Stew,
Look here: Mcmaster
They won't ship to you, however, the warehouse is about 5 miles away from me. I can send them to you if you need.
