Author Topic: Globe Valve  (Read 11215 times)
Offline BK
Globe Valve
« on: April 10, 2010, 03:22:17 AM »
I need a 90 degree globe valve, has anyone tackled making one??
It will be small, 1/8" ID steam pipe (low pressure)
If it aint broke, don't fix it!
Re: Globe Valve
« Reply #1 on: April 10, 2010, 03:46:50 AM »
Hi BK
I've made small globe valves for LC Masons Mini traction engine, there are a few designs about if you look at LBSC loco plans you will find a drawing, if your stuck I'll post a Crap O Cad drawing for you here.
There quite simple to make straight forward turning job the hardest part is silver soldering it together as you can clog up the works if you use too much solder.
Hope this helps
