Author Topic: Potty Finger Engine  (Read 50095 times)
Potty Finger Engine
« on: April 04, 2010, 12:35:19 PM »
Hi Chaps
This is a slight diversion from my Loco build but I've been wanting to build a finger engine for some time and kept my eys open for ideas that would add a bit of interest to the build. I saw a thread over on HMEN where the chap added some engine turning to a horizontal engine that looked real nice this set the little grey cells going.  :scratch:. Then on one of my scouting trips to the scrappy I spotted these
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3492.jpgPotty Finger Engine
The scrap man saw scrap I saw flywheels.
First job clean up one of those discs
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3493.jpgPotty Finger Engine
Then grind up a form tool out of a broken cutter, to use as a flycutter.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3497.jpgPotty Finger Engine
Then set my indexer over 5 deg, and mount a chunk of 2 3/4" dia ally in the chuck, that ally is way too long but I didn't want to cut it down and wast material as I'm planning on using it on another job.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3498.jpgPotty Finger Engine
This is the set up for flycutting flutes across the face with that formed flycutter. Th angle plate is to support the bar against the push from the cutter.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3500.jpgPotty Finger Engine
And this is the result 36 flutes across the face of the bar.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3502.jpgPotty Finger Engine
And this is what it will look like as a fly wheel hub.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3505.jpgPotty Finger Engine
Have fun
Re: Potty Finger Engine
« Reply #1 on: April 04, 2010, 12:38:49 PM »
Forgot to post the drawings
« Reply #2 on: April 04, 2010, 12:39:26 PM »
And sheet 5
« Reply #3 on: April 04, 2010, 01:07:32 PM »
Very neat Stew. I like the idea that you picked for the center of the flywheel. I think that you are going to see that idea used a few more times on the two forums. Will be a nice little finger conditioner when finished.  :ddb: :ddb:
« Reply #4 on: April 04, 2010, 05:27:46 PM »
Stew,
Very neat design idea. I like those splines.  :thumbup:
« Reply #5 on: April 04, 2010, 07:19:18 PM »
Now I like that!!!  :jaw:
I'm going to have to have a go with some brass at some time.... All sorts of effects have just been opened up to me  :ddb:
Cheers Stew  :thumbup:
Looking forward to your take on one of these.... I've still got 4 to finish! All about half (ish) made have been for best part of 12 months   ::)
« Reply #6 on: April 05, 2010, 01:39:51 AM »
 :poke: :poke: :poke: :poke: :poke: :poke:
« Reply #7 on: April 05, 2010, 04:54:27 AM »
Thanks Guys
Doing that flutting worked out better then I expecting, it just takes quite a while to go the circle (45 min) I did it in two cuts:- 2mm rougher and a 0.25 finisher.
Got a bit more done this morning.
Part off from the bar stock if you tried parting off this thickness in one go you'd end up in trouble, best way is to do it in steps so you keep the groove twice the width of the tool, then for the last bit just adjust the cut so that your bringing the disc to thickness.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3508.jpgPotty Finger Engine
And her's the first disc stuck in the rim with high strength loctite.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3510.jpgPotty Finger Engine
Looking good  :thumbup:
Have fun
Offline zeroaxe
« Reply #8 on: April 05, 2010, 05:01:46 AM »
Jsut a quickie about the Loctite. I assume that itis put all around the edge of the hub? And if so, once you put it in place, did you have to wipe off any residual Loctite in all the grooves(or "V"s) ?
Looking good there :thumbup:
So much to learn, so little time - Author Unknown
« Reply #9 on: April 05, 2010, 08:33:29 AM »
Hi Stew,  that's a great looking center for the flywheel, I like the way you did the fluting, I'm going to have to try that on an engine for the wife, maybe a finger engine to keep her finger occupied, and out of trouble.  Nothing quite like aluminum and brass working together for good looks. Mad Jack :beer:
« Reply #10 on: April 05, 2010, 09:12:49 AM »
I have to admitt that is one cool looking flywheel Stew. I think you out did yourself on this one.
Now I'm going to have to try that, darn you.  :lol:
« Reply #11 on: April 05, 2010, 11:55:42 AM »
Thanks Guys
Look like this ones giving you all a good dose of  :proj:
 :D
Zeroaxe
I was very mean with the loctite just put a few drops in the rim and spread it round with a coffee stick, I had nothing to clean away, you don't need much loctite to get a good fix that I've had that  10ml bottle for about three years and I've used it on quite a few jobs.
« Reply #12 on: April 06, 2010, 03:47:26 AM »
Finished off the disc for the other side, and loctited it in position.
One bit of kit I've found very handy especially for getting things clean for gluing etc is one of those elcheapo ultrasonic cleaners, I use it far more than I thought I would.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3511.jpgPotty Finger Engine
And here's both side of the fly wheel, I've got to bore it out for the bearing but I'm still waiting for them to come in from Hong Kong, and drill and tap for the crank pin.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3515.jpgPotty Finger Engine
That seems to have worked out great.
Offline John-Som
    • Start Model Engineering
« Reply #13 on: April 06, 2010, 06:04:47 AM »
Hi Stew
Interested in your use of ultrasonic cleaner. Since the ban on tricoethylene I have struggled to find an effective alternative. Can I ask what you use these days ?
John-Som
start-model-engineering.co.uk - a friendly place for model engineering beginners
« Reply #14 on: April 06, 2010, 07:26:48 AM »
Hi John
I just use water and washing up liquid, you can just use water for light cleaning, also other things can be added to the water but you'd have to do a bit of research on that. I've used it to clean parts for silver soldering, seem to work Ok for me.
« Reply #15 on: April 06, 2010, 08:25:10 AM »
First Stew, neat trick on the photography using a mirro to show both sides at once. Had forgotten about that trick.
Second, you can use a jewlery cleaner in the ultrasonic cleaner. I'm sure that can be found a better jewlery stores.
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #16 on: April 06, 2010, 09:19:53 PM »
Oh, it's a mirror!  First glance, I though it was two different flywheels.  Ya caught me looking, Stew.
Potty Engineering strikes again!
Looks great.  Quite unique.
Dean
Dean W.
Shop Projects:
« Reply #17 on: April 07, 2010, 04:29:08 AM »
Thanks Bernd/Dean
Bernd I'll try that jewelry cleaning stuff, I think my boss has some hidden away, thanks for the info.
The mirror is my hair cut mirror I keep in the shop:- No I won't be starting a thread "Giving Stew an haircut"  :D
More progress this time on the columb, turned a length of ally down to 15mm diameter than transfered it over to the mill and in the indexer with a 3/16 ball ended slot drill put 12 flutes up it.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3516.jpgPotty Finger Engine
Then gripping it lightly in a collet face, drilled and tap both ends M3
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3528.jpgPotty Finger Engine
Milled a little square base up:- sorry no pics.
Then in the lathe by eye shaped up the roundels drilled 3mm and part off.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3524.jpgPotty Finger Engine
And this is what the columb will look like.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3526.jpgPotty Finger Engine
I want the engine to look like the Temple of Afinger the Greak Godess of Engines  :)
Have fun
« Reply #18 on: April 07, 2010, 07:43:08 AM »
 :offtopic:
Good crop of frog spawn this year.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3530.jpgPotty Finger Engine
OK Stole a few more shop hours and got stuck into the the columb cap.
First op on the lathe.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3532.jpgPotty Finger Engine
Then onto the indexer for milling the flats, and drilling and tapping M3 blind
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3534.jpgPotty Finger Engine
Then back onto the lathe to part off
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3535.jpgPotty Finger Engine
A quick clean up and a polish, and this is where it fits
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Finger%20Engine/100_3536.jpgPotty Finger Engine
« Reply #19 on: April 07, 2010, 09:24:01 AM »
Hi Stew, you're sure enjoying the use of that mirror aren't you?  I have to say, with those Greek columns set up, you've got a lot to live up to on this finger engine build :jaw: Mad Jack
« Reply #20 on: April 07, 2010, 09:59:19 AM »
:offtopic:
Yummy, slightly salted and they will do nicely  :)
Nice work, like the column  :thumbup:
« Reply #21 on: April 07, 2010, 11:42:14 AM »
Cheers Jack/Darren
Darren I prefer mine with Garlic  :D
« Reply #22 on: April 08, 2010, 06:15:58 AM »
Stew nice work, this is going to be a unique finger engine!  :bow:
Offline Dean W
« Reply #23 on: April 08, 2010, 11:07:52 PM »
Column looks fab, Stew.
That type of indexer would sure be handy.  I wish they made a smaller one!
Dean
Dean W.
Shop Projects:
« Reply #24 on: April 09, 2010, 08:46:11 AM »
Thanks Bernd/Dean
Have fun
Stew Anyone wanting a thread on hair cutting, I'd be glad to post a few pictures but they get gruesome!!  mad jack
