Author Topic: Dividing head for the shaper  (Read 14831 times)
Offline mhh
  • Country: dk
« on: March 21, 2010, 04:23:16 PM »
I ran into some trouble awhile ago,I had this pulley that should fit over a bigger shaft than the original, so I bored and reamed the hole, no problem there, went over to the shaper to make the keyway, so i put it in the vice and SLAM! the pulley bent in the vice!
So to avoid that happening again I'm going to make a simple dividing head and fit a 11" 3 jaw chuck that way I should be able to clamp future pulleys that needs broaching, without the possible danger of bending them!
I apologize for the large pictures.
This is about 62kgs of steel
First few cuts at 160rpm 0.15
300mm to 140mm (roughing) started from 160rpm 0.03 feed and 5mm diameter(2.5 depth) and ended at about 250rpm same feed and depth.
Finished surface (130mm) about 315rpm 0.015feed and 0.5 in depth really nice result.
Treaded M130x1
Drilling 50mm hole
Boring from 50mm to 90mm
The 11'' chuck
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: Dividing head for the shaper
« Reply #1 on: March 21, 2010, 04:28:44 PM »
 :jaw: :jaw: :jaw: :jaw: :jaw: :jaw: :jaw: :jaw:
Holy cow, my lathe weighs less than that!!!!!!!!
Interesting project though, I look forward to more  :coffee:
Tim
« Reply #2 on: March 21, 2010, 05:35:39 PM »
Well..... Your certainly not mucking about are you  :jaw: :bugeye: :jaw:
Got to love the chuck jaws!!! I don't think I'll ever be quite that adventurous though  :coffee:
The pic's loaded for me in a few seconds, so I'm fine  :thumbup:
« Reply #3 on: March 21, 2010, 06:46:45 PM »
Wow! Thats a hunk of steel. Love the blue chips! I am with Tim... my lathe weighs less than that!
« Reply #4 on: March 21, 2010, 08:00:49 PM »
I realy like the way you welded those extra jaws onto the chuck jaws and turned them to fit that piece of steel. Nice idea.
That's more than my girlfreind weighs.  :lol:
« Reply #5 on: March 21, 2010, 08:22:25 PM »
Crikey, my DH weighs that much, can't imagine spinning that in the lathe .... or getting it in there to start with  :bugeye:
« Reply #6 on: March 22, 2010, 10:21:56 AM »
I have to say that is machine work at its best, welding on to chuck jaws, just to fit a part in the chuck which doesn't fit.  It looks great, I love to see the power of blue chips, running coolant, and a nice, smooth finish.  I'm looking forward to the rest of this, I was just considering making a dividing attachment for my own shaper although I suspect it's smaller than yours.  Mine's a seven inch Atlas, that chunk of steel would barely fit on the table, far less be machinable on it.  How big is the shaper you are using?  Can't wait to see the rest of the log.  Mad Jack :whip:
Offline Trion
« Reply #7 on: March 22, 2010, 02:00:24 PM »
Er du syk, mann?
I didn't realize the size of the piece until I saw your hand holding the garden hose for the coolant. :jaw:
« Reply #8 on: March 22, 2010, 02:17:33 PM »
Er du syk, mann?
No Trion, I think mhh is just showing off how good he is getting at lifting heavy weights, after all the hard work building his huge new shop  :lol:.
It must be great to have the machines capable of taking big work like that.
Offline Stormin
« Reply #9 on: March 22, 2010, 04:06:17 PM »
And most of it is now swarf!
Didn't you consider using a thinner piece of plate and adding the central boss as a seperate piece?
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #10 on: March 23, 2010, 01:35:07 AM »
I think just the chips from this would fairly cover my lathe.
Dunno about everyone else, but I'm itchin' to see part 2!
Dean
Dean W.
Shop Projects:
Offline mhh
  • Country: dk
« Reply #11 on: March 25, 2010, 04:19:15 PM »
I actually did consider it, but decided not to because the Ø300 piece was scrapped anyway so it was cheap. And besides everyone loves making swarf.
« Last Edit: March 25, 2010, 04:21:11 PM by mhh »
