Author Topic: Oh say can you see.....  (Read 6409 times)
Offline PTsideshow
« on: March 16, 2010, 02:03:52 PM »
Oh say can you see the flaming Propane cylinder around 1:38 to 1:40 into the vid flying screen left and goes boom. Dallas I believe 2007
About 7 minutes long
Here is a  Fire dept training vid looks to be from England.
a quickie
Of course it was probably only an acetylene cylinder.
And on the page there are the usual assortment of Darwin award tryouts from the knuckleheads at the local tire shop playing with it inside the bay with a car near, To bored US solders in Iraq , figuring out a new way to remove eyebrows.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: Oh say can you see.....
« Reply #1 on: March 16, 2010, 03:56:05 PM »
a quickie
Typical Sherpa van, can't even do rocket propelled properly!  :lol: Mind you, that little lurch it gives at about 3s is probably as far as it ever moved under it's own steam....
You don't need to have acetylene or propane for a potent explosion though: Here's a few volts of electricity and a few gallons of oil:
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
« Reply #2 on: March 16, 2010, 04:10:28 PM »
And here is a few volts (well a  few hundred), and nothing else.
If it works, take it apart and find out why!
« Reply #3 on: March 16, 2010, 04:32:39 PM »
To explode like that, it would most likely have been an oil-filled breaker. It does happen, though, and depressingly frequently, even here in the UK.
