Author Topic: Stick Electrodes for Carbon and Low Alloy Steel  (Read 9697 times)
Offline PTsideshow
« on: August 17, 2008, 06:02:59 AM »
Weldirectory
by Lincoln Electric
copyright©1998
Publication C2.10
http://i35.photobucket.com/albums/d200/ptsideshow/assorted/welding%20books/Books0229.jpgStick Electrodes for Carbon and Low Alloy Steel
If you ever wondered why, are there so many electrodes other than sizes. And then the question of which one for which application. This is the booklet for you.
It starts with How to select electrodes, then gives some suggested ones for the common trade name steels. Then moves on to the Fast Freeze group, Fast Fill groups, Low Hydrogen group, and Low Hydrogen,Low Alloy Steel Group. And finishes up with all you ever wanted to know about the AWS numbering System.
In each grouping of electrodes it covers:
    * Specific Electrode applications
    * Electrode Identification and operating data
    * Mechanical property requirements
    * Mechanical properties test results
    * Conformances and approvals
It has the charts and some line drawings to illustrate the topics covered. It also has the basic selection process down into 4 sections. The general methods going to be used to fabricate and steel type, Code Quality,Carbon Steel Welding, or High Strength and Low Alloy Steel welding. Again this one is punched for a 3 hole binder cover.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
