Author Topic: Little surface gauge-H.Hall design  (Read 13371 times)
Offline Xldevil
« on: March 12, 2010, 01:27:53 PM »
Hello.
I´m trying to improve my skills and bought H.Hall´s book:Lathework-a complete course.
For my first project,I´m building the little surface gauge.
Now that it comes to the cut that has to be sawn in the base as a part of the adjustment fixture,I´m wondering if it´s meant to be circular or just at one side.The drawing and the text is not that clear to me.
Did anyone build that gauge too and can give me a clue?
I´ve found to pictures of a finished gauge:
http://images.google.de/images?q=surface%20gauge&um=1&ie=UTF-8&sa=N&hl=de&tab=wi
Last row,the one at flickr.com.with the round base.
The V-groove, that is meant to camouflage the unsightly handsawn cut,is going all around;but I can´t see the sawn cut in itself.
Anyway,here are some pictures of my current progress:
The base is turned already.Trying to level the base for flycutting the flat and drilling the holes.
Holes drilled,than deburred.
Turning the necessary thin piece collet.
Cheers,Ralph
« Last Edit: March 12, 2010, 01:49:59 PM by Xldevil »
Offline No1_sonuk
Re: Little surface gauge-H.Hall design
« Reply #1 on: March 12, 2010, 03:06:29 PM »
The cuts are straight across, leaving a 2mm piece of material to act as a "hinge".
The top, right drawing on page 19 is a cross-section through the cut, and shows the 2mm piece with diagonal hatching lines.
Offline Xldevil
« Reply #2 on: March 12, 2010, 04:21:50 PM »
Hello.
You don´t waste any time to exchange pleasantries.
Anyhow,thank you for your help.
ASFAICS the cross section drawing shows only one straight cut on the left side.If I got you right,I have to saw 4 straight across cuts,one on each "side",correct ?And then there should only last a hinge of 2mm in the middle of the base? :scratch:
Regards,Ralph
Offline No1_sonuk
« Reply #3 on: March 12, 2010, 05:12:21 PM »
Hey,
Looks like 2 cuts to me, one shallow on the left, and one very deep on the right.  The 2 "ends" of the hinge are formed by the initial turning of the groove.
Offline Xldevil
« Reply #4 on: March 21, 2010, 01:12:55 PM »
The brass to make the adjustment bush is on the lathe
« Last Edit: March 21, 2010, 01:14:52 PM by Xldevil »
Offline Xldevil
« Reply #5 on: March 29, 2010, 01:12:53 PM »
Hello.
To come to an end,the gauge is finished.
More or less,the "fine adjustment" seems to be useless.Maybe I did something wrong?
Anyway,the making offered me some good options to improve my skills.
My next and more demanding project will be a rear toolpost for my Super 7.
Cheers,Ralph
« Last Edit: March 29, 2010, 01:43:10 PM by Xldevil »
« Reply #6 on: March 29, 2010, 03:11:55 PM »
Hi Ralph  :clap: :clap: :clap: :clap:
That looks a handy gauge  :thumbup:
cheers Rob
« Reply #7 on: March 29, 2010, 03:57:31 PM »
Very nicely done Ralph!  :clap:
That looks purposeful, solid, chunky........  :thumbup:
Probably much more use to the likes of us, than my full size/ oversize one, made as an apprentice in 1960.  ::)
