Author Topic: Hello from Scunthorpe  (Read 12007 times)
Offline davidcurtis021
« on: March 07, 2010, 04:54:23 AM »
hi all
as you can see from my username i am called david  i am a mushroom farmer just beggining to ponder retirement in five years time i come here as a collector of manufactured steam toys and my primary aim is to set up a small workshop to enable me to make those spares you can't buy.
I have no knowledge of macine tools other than a pillar drill and a rigid pipe threading machine. Luckily i have a friend from another forum and a member here who has taken me under his wing.
outside of work i am incredibly lazy and if there is a way to cheat i'm all ears.
so here is my first question my starter for ten as they say. thinking about setting tools to cut on the centre line is there a reason why you should not mount a laser pointer in the tailstock and disect the beam with the tool point.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: Hello from S horpe
« Reply #1 on: March 07, 2010, 09:26:32 AM »
Hi there David :wave: welcome to Madmodder.
About setting the tool height at centre with a laser, thinking about it, it might work, but some of the laser pointers I've come across have a fairly wide beam, ie 1mm or more. Also you would have to make sure that the tailstock was in allignment each time you used that method.
The method I've found to be quick and easy is to gently trap a 6" engineers rule ( or even better a 12" rule ) between the tool and the workpiece. If the rule is exactly vertical then the tool is set on center. It may not be exactly on center, but it is close enough and when taking a facing cut you will be able to finely adjust it to perfectly spot on centre.
Tim
Offline CrewCab
Re: Hello from Scunthorpe
« Reply #2 on: March 07, 2010, 10:43:28 AM »
Hi David, welcome aboard  :wave:
CC
« Reply #3 on: March 07, 2010, 01:04:29 PM »
Hi David,
You're just the other side of the bridge to me....I'm just outside of Hedon near Hull
« Reply #4 on: March 07, 2010, 01:34:57 PM »
Hi David
Welcome to MadModders. I see you have already got an answer to your question. If you have any more, ask away as there is always someone around to answer or at least offer an opinion. There are members here that repair as well build steam toys so you will fit right in. When you get a chance you might post up a few pictures of your collection as  :worthless:. Looking forward to your participation in the forums  :D :D
Offline SKIPRAT
  • Gainsborough Lincolnshire England
« Reply #5 on: March 07, 2010, 01:35:51 PM »
Hi David from a few miles south of you i am located in Gainsborough have fun and most of  all ask questions thats the way to go.
Cheers Paul  :beer: :beer:
« Last Edit: March 07, 2010, 05:24:05 PM by SKIPRAT »
One Mans Junk Is Another Man's Treasure G6FOW
« Reply #6 on: March 07, 2010, 01:48:45 PM »
Hi David,
« Reply #7 on: March 08, 2010, 01:05:22 AM »
Hi David,
hi john i was born on Hedon Road just opposite the prison 99 Newtown Buildings i know they are still there dont know whether they are still called Newtown Buildings though
« Reply #8 on: March 08, 2010, 04:13:02 AM »
Hi David,
Welcome to the collective.....   :wave:
Nice to see you made it from over there, to over here here!  :thumbup:
All your questions will be answered! But, not always the same answer! This is a funny old game......  :scratch:
Join in. Show pics. Enjoy!  :D
PS.
I`ve got yer first artifact...... A bottle of slide oil!  :)
