Author Topic: Drill Chuck Problems  (Read 13017 times)
Offline 75Plus
« on: February 03, 2010, 08:54:41 PM »
Am I the only one that finds that the Asian chucks or chuck keys seem to wear rapidly. Every one I have started slipping when tightening or releasing in a short period of time. I have several Jacobs and other US made chucks that are still tight after over 50 years of use. :doh: :doh:
Joe
Re: Drill Chuck Problems
« Reply #1 on: February 04, 2010, 02:17:35 AM »
Joe,
The chuck supplied with my Chinese bench drill "stripped" internally during it`s first week of use......  ::)
Successfully replaced by a cheap 13mm chuck off Ebay.  :thumbup:
My X2 type mill`s chuck "stripped" internally during it`s first month of use........  ::)
The Ebay chuck is now on the mill, and still giving full satisfaction!  :clap:
I guess you can say Asian quality is variable.......
Offline 75Plus
« Reply #2 on: February 04, 2010, 10:17:07 AM »
David, My problem is with the key. After a short period the key starts slipping on the teeth of the chuck. I think it has to do with the fit of the key to the chuck. I just don't know how to improve the fit.
Joe
Offline wheeltapper
  • Spixworth Norfolk
« Reply #3 on: February 04, 2010, 10:38:41 AM »
you could try machining a small amount from the narrow end of the taper so it goes in the chuck teeth more.
Roy
« Reply #4 on: February 04, 2010, 11:57:43 AM »
Roy
Yes! I`ve done that too....
Also, always push the key towards the teeth, so it is held tight in engagement......  :thumbup:
Never had a problem with my own keys. Often had problems with communal keys, (at work)!  ::)
Offline ibuildstuff4u
« Reply #5 on: February 04, 2010, 08:52:02 PM »
I have six tail stock chucks for my lathe and some of the keys that came with them fit really sloppy so I tossed them and just use the ones that fit good.  Perhaps you can find a good quality key at your local hardware store that will fit better.  The keys that come with the chucks are poorly made.
Dale P.
