Author Topic: Press Fits and other questions  (Read 17275 times)
Offline fluxcored
« on: February 03, 2010, 01:34:54 AM »
Hi Guys,
I'm spending more and more hours on doing lathe work and am getting better finishes and accuracy all the time. I'm becoming faster as well, as I gain more confidence.  I'm grinding my own tools and seems to improving on that front also but still have a long ways to go. I'm becoming more optimistic that the lathe will survive me!
Where I need some help and advice is on press fits. I want to turn a bush for a pulley with a 18.56 mm diameter hole. Just to fly by my research and math - from Machinery's Handbook I calculate the diameter of the bush required for a press fit to be between 18.54 to 18.52 mm. It may be wrong.
Now for the million dollar question. How the heck can a newbie like me with an old Boxford lathe turn to 0.01mm tolerances? I have got a good micrometer and a Chinese dial gauge so I know I'll be able to measure in that range.
I guess even preceding that question is - my lathe is imperial and I sometimes get confused a lot. My general rule of thumb is that 10 graduations on the dial remove 0.4mm of material. So a single unit of graduation removes 0.04 mm of material. Does that sound correct?
Also backlash - I still do'nt know how to counter that? I try to not to reverse the feed direction when I start cutting but that is not always possible.
Also polishing/finishing - I will need to polish the bush with sandpaper to get it really smooth. How much allowance should I make for finishing. I'll be using ordinary mild steel that's why sanding will be necessary.
I know I'll be able to get the bush to 18.6 easily. The last 0.06mm is going to be a tough one for me.
Sorry for the long post!!!
Regards.
"Living is a dangerous occupation. Just look at all the dead people out there." - Thomas Lipton
Re: Press Fits and other questions
« Reply #1 on: February 03, 2010, 03:10:26 AM »
I can only assume your machines in reasonable condition so:-
First you want to make the shaft fit the hole its easyer to get an accurate OD than a bore.
Second good sharp tool. Back lash you wind the tool back away from the job then wind it towards the job, as long as you keep going in the same direction it will be ok but if you have to change direction wind the tool well clear then start winding in again, hope this makes sense. Turn the job down  close to size (+ 0.2mm ish) take an accurate measurement, work out the final cut put the cut on and Bobs your uncle, you should have the size you want.
Metric/Imperial  you're roughly correct in 0.1mm = .004 " Its actualy 3.937 " but for most jobs 0.004 " will be accurate enough.
I've got metric machine and measuring kit, but use a lot of imperial drawings so what I do is convert the imperial size to metric I just find it easyer that way.
Hope this helps
« Reply #2 on: February 03, 2010, 04:16:57 AM »
Hi Flux!
What works for me...... Mostly!
Always machine bush o/d to fit bore.
Rough the bush o/d to +.1mm oversize, leaving 3mm or so extra on it`s length.
Machining in the 3mm extra length area only. Take very light cuts, (half a graduation), until the pulley will just slide on....... This gives you your dial reading for a sliding fit!  :thumbup
The interference fit setting is "half a graduation" out from that.
Handwheel, 1/2 turn out, to eliminate backlash & then approach "half a graduation out" in 2 or 3 passes.
I often leave the 3mm portion on for alignment purposes, for when fitting the bush.
Much easier to do, than to explain......  ::)
Good luck!
« Last Edit: February 03, 2010, 04:18:51 AM by Stilldrillin »
Offline fluxcored
« Reply #3 on: February 03, 2010, 04:44:11 AM »
Guys, thanx. Stew you confirmed that my thinking's basically correct and that I'm on the right track.
Dave, your method makes perfect sense!!
Thank you both for taking the time to point me in the right direction. I am truly having fun and what's so good about the experience is knowing that I can fall back on you guys and this board for guidance.
I have got a brand new 4 jaw chuck to fit but feel the time is not right for me tackle that job. Maybe after I'm done with the pulleys.  :D
Regards.
Offline ieezitin
« Reply #4 on: February 03, 2010, 08:40:53 AM »
Flux
Regarding your backlash. Every machine has it so you have to get used to it.
I look at the problem this way. Its  all about knowing where you are in measurement terms.
If every machine had a DRO on it then you would never really have to think about backlash again but I am assuming you do not so go to the next best thing your dial indicator.
Example here. If you were turning a shaft and you had the indicator connected to the tool holder cross slide if you needed to pull back you could as the dial in not lying to you where it is in space. As it has been already said make sure you pull back quite a lot and get a good bite back in and if no pressure is let off you are good to go.
OK now your bushing problem. I read it this way, you want to turn down a bushing insert to fit an existing hole of a pulley of 18.56mm diameter.
Well your lathe is more than capable of turning down .004 and so are you. By being slow and determined while watching and noting everything what’s happening while you are turning down to your finial size of your bush.
Here is how to do it. Get close to your finished size lets say .020 ( note down measurement of od of bush now) then stop. Take off your tool bit and make sure its sharp if not dress it up. So! Nudge the tool tip into the job so it just kisses it then take a pass. Take note of measurement if it took some off .
Now slide to tool in .004 by your dial and make a pass get to the end and stop the tool and the machine do not run the tool back!. Note the diameter reading! Did it cut .004? If it did good if it did not make a note!. Now reverse your tool back on the back cut and let it finish then stop and take another measurement. By doing this you have established what your machine does or as I like to say “ she shows her personality she’s telling you what she likes.” By using these two measurement tests you will be getting a fare idea on what’s happening on the cuts plus your confidence level rises on making the cuts.
Always make notes and jot down sizes often, this way you will eliminate a lot of silly mistakes and in turn get to know your machine.
If you a .001 away then hone with emery cloth, always wet with oil I use WD40. Try also when machining build in little comforts like offering up the fit to the piece in the chuck.
I work this way. When I am making something I always think of if I screw up what would be the best way out of it? Example your bush!. I would go for final size with confidence but if its wrong I would rather it be undersize than oversize. If its undersize  and it’s a little bit slippery in the hole you can always center punch lots of little dots on the outside of the bush and beat in with a hammer : ) its not the space shuttle right!.
Hope this has been a help to you. One more piece of advice machining is easy, it’s the little tricks that are hard.
All the best.     Anthony
Offline fluxcored
« Reply #5 on: February 03, 2010, 09:36:35 AM »
Hi Anthony,
Thanks for the advice. Really appreciate it a lot. It'll take time before everything starts to click but I'm very hopeful. It is becoming easier as I go along and I can visualise what needs to be done.
When I started out it was like moving through a fog that's why I set my goals low and not be too adventurous initially.
I just want you all to know that you do make a difference.
I'll update you guys on how it turns out. I'll get a few pics and upload it via the PC at work. Am still fixing my home PC.
Regards.
« Reply #6 on: February 03, 2010, 10:51:36 AM »
I hope you don't mind me sticking my nose it but the above is not strictly true. I know what you are getting at but some new guys might not.
When you feed at tool in you want the backlash in front of the cutting forces so that the tool does not get pushed back during the cut.
Normally achieved by always feeding towards the work. If you go too far and pull back just make sure you pull back far enough to necessitate the need to feed in again thus taking up backlash.
But yes the DRO will tell you where you are when the dials may not. What the DRO won't tell you is where the backlash is.  :thumbup:
I hope that make sense  :scratch:
Offline ieezitin
« Reply #7 on: February 03, 2010, 11:37:28 AM »
Darren.
On the contrary your input is more than welcome this is what this forum is all about.
Its funny I thought I explained what you remarked on, I am sure there’s always this, three people can read the same thing and get three slightly  different views from it, I know I suffer from it.
Yes you are 100% right  DRO will not inform you of your backlash.
I have a Atlas 12“, its about 30 years old I have had it for about 12 years anyways the cross slide is so sloppy always has been I have given up on trying to keep finessing with the Jib screws, religiously I drive forward about an inch get close to my cutting position and when ready I pull with my hand back on the cross slide to bed it, seams to work for me. I also have the jib screws tight more than I should. Which in turn plays havoc on my wrists.
Its an awkward machine to use, but after knowing and using it  for so long now and I know all its quirks it produces some nice stuff.
All the best.    Anthony.
Offline kvom
« Reply #8 on: February 03, 2010, 03:15:03 PM »
My lathe has a DRO, and it shows you where the backlash is when the crossfeed moved during cutting.
I recently had to do some boring, and I had to move the took towards the work, but back towards me.   So that jives with what Darren said.  Took me a few passes to get the idea.
Similarly, when using my taper attachment I need to cut from the large towards the small end of the taper for best results.
Offline fluxcored
« Reply #9 on: February 09, 2010, 12:44:39 AM »
Hi Guys,
Just for an update. I managed it with confidence. Problem is, on the one pulley I want to remove the bush now but can't. That's typical of some of the situations that I get myself into.
Thank you all for assisting me.
Regards.
Offline ieezitin
« Reply #10 on: February 11, 2010, 01:30:59 PM »
Flux.
Couple of ways to remove the stubborn bush. Drill it out with step sizing drills ( drills slightly larger than the last drill used) and leave just a slight shell then ping out with a Cole chisel.
Stick it on the face plate and machine it out. That way your boring out to a given size and making a nice fit for the new bush.
Or drill a hole of about 7/16 then use a hacksaw blade to notch it out, run the cuts parallel along its axis then whack out with the chisel again. The objective being to make it collapse.
Offline TriHonu
« Reply #11 on: April 20, 2010, 01:20:50 AM »
Fluxcored to accurately take smaller cuts you have to use the compound.
Picture this:
1. If the compound is set so it pointed away from the operator (90 degrees to the axis of rotation) a turn the compound screw one division and the tool will advance .0005 in and will remove .001 inch from the diameter.
2. If you turn the compound 90 degrees so it is pointing at the chuck.  If you turn the compound dial 1 division, the tool will move .0005 toward the chuck.  It will not move any closer to the axis of rotation so it will not remove any material from part.
3. There is some setting on the compound between these two settings that will allow you to turn the compound feed 1 division (.001 inch) that will remove .01 mm.  If my math is correct the compound angle you want is 23 degrees.  Start with the compound pointing at the chuck.  Turn it clockwise 23 degrees and lock it down.  Make a cut.  Measure the diameter.  Advance the compound 1 division.  Take another cut.  If you are using a sharp finishing tool, you should remove .01 mm.  :thumbup:
On an Imperial lathe, setting the compound 6 degrees from parallel to the axis of rotation will remove .0001 from the diameter for each .001 advancement of the compound.  Setting the compound at 30 degrees will remove .0005 from the diameter for each .001 advancement of the compound.
« Reply #12 on: April 20, 2010, 01:51:01 AM »
Picture this:
TriHonu
 :D :D :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :D :D
Congratulations TriHonu. When you joined up to MadModder this morning you became the 1000 th member to join up. Perhaps you could start a new post in the "Introductions" thread and tell us a bit about yourself and your projects. From the sound of this post I am sure that you must know your way around a lathe very well and probably other machines as well. I hope that you enjoy the forum and if you have any questions just ask, there is always someone around to answer or at least give and opinion.  :ddb: :ddb:
Offline fluxcored
« Reply #13 on: April 20, 2010, 03:09:20 AM »
I have'nt touched this project for quite a while now. Been focusing on a few other tasks. I've finished my ...forge..., if you can call it that and plan to heat the pulley to see if I can remove the stuck bush that way. Hopefully it will not warp the pulley.
Anthony, I would like chuck it on the lathe and to machine it out but it's too big for my lathe. Hacksaw and chisel is what I'll use next if heat does'nt help.
TriHonu, I guess I understand what you're saying. I'll play around and report back.
Cheers and Thx.
