Author Topic: making a new base for a shop lamp ...  (Read 14340 times)
Offline wquiles
    • Work and projects ...
« on: December 30, 2009, 08:02:25 PM »
Good lighting helps with the pictures that I take, and I typically use two lamps, one on each side.  About a week ago the weak plastic base of one of them (of course, the cheaper one!) broke off:
I decided to make something a "little" bit stronger by using a small rectangular piece of 6061.  It was also an excuse to try out the higher HP motor on my VFD conversion.  I started taking a 0.5" wide cut, and taking 0.030" and larger chunks to see how well it worked.  Here I am cutting with a two-insert 1" dia cutter:
You can see the progressively larger cuts on the first side (top to bottom, all of them at 0.5"):
but on the other side I got more aggressive and cut the 1" inch cut on 3 passes: 0.3", 0.3", and 0.4" (again, all of them at 0.5"):
I then finished cleaning up the edges a little (no effort was made to  make the part look pretty):
then drill all 5 holes:
The finished piece next to the broken one:
and in use, with the original cheap lamp:
and with the heavier, much nicer lamp:
Will
Machining and electronics - www.atdms.com
Offline chuck foster
Re: making a new base for a shop lamp ...
« Reply #1 on: December 30, 2009, 08:11:54 PM »
nice job will  :thumbup:
i had the same problem with one of the lights in my shop..........so i did the same as you.
chuck  :wave:
skype:  aermotor8
former hmem member
« Reply #2 on: December 30, 2009, 08:41:51 PM »
Nice job there Will..... Makes me feel all lazy!!
I just drilled a hole through my bench for mine! ::)
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #3 on: December 30, 2009, 09:47:51 PM »
Nice job!!! I buy those at thrift stores and they are always missing the base. You can pick them up for a couple of bucks usually. Here is a base I make. It's wood that's glued and screwed together. Then a coat of paint and your set:o)
http://img.photobucket.com/albums/v652/Powderkeg3418/Lighting001.jpgmaking a new base for a shop lamp ...
Wesley P
Offline wquiles
« Reply #4 on: December 30, 2009, 11:17:53 PM »
Thank you guys.  I am also happy to see that I am not the only one using these lamps.  It is cool to hear and see how you guys have dealt with the poor/fragile bases - there are many ways to skin this cat  :D
