Author Topic: Addition to Rose Engine  (Read 16669 times)
Offline old-biker-uk
  • Taunton, Somerset
    • An Old Biker's Stuff
« on: December 28, 2009, 04:03:05 PM »
This was one of those projects started years ago (like so many others!).
With the Rose Engine up and running (if not finished) I dug out the eccentric chuck bits and finished it.
Built to the design by J.A.Batchelor in Model Engineer Magazine, May 1991
Mark
What you say and what people hear are not always the same thing.
Offline RDL
Re: Addition to Rose Engine
« Reply #1 on: January 02, 2010, 06:40:46 PM »
Mark
This project and your work interests me.  Is it possible to see more close up pictures and drawings?
Raymond
  • Taunton, Somerset
« Reply #2 on: January 03, 2010, 09:09:20 AM »
Raymond - Check your PMs
Some more pics of the chuck:
The backplate was welded up from mild steel, the slide hacked out of hot rolled MS with my trusty angle grinder then scraped flat. The original design had a 5/16" x 20 screw but I modified that to 5/16" x 40 to give a finer adjustment.
Basically a good exercise in fitting & turning....
I made it for ornamental turning but could also be used for turning eccentrics for model engines etc. (wouldn't want to run it too fast though!)
Here's a couple of turned bits, boxwood, about 2" high.
Mark
