Author Topic: Homebrew boring bar holder  (Read 11039 times)
Offline kvom
« on: December 21, 2009, 09:19:59 PM »
Until today I didn't have a good way to bore on my lathe.  I previously made an aluminum holder to use with a broken endmill, but that didn't ever work very well, and the endmill is 1/2" diameter which elminated small holes.  So I tended to rely on reaming to get a precise hole.
A while back I purchased a couple of "micro" carbide boring bars from a seller on PM, but they had lain unused for lack of a holder.  Today I decided to make one.  Here's the larger bar.  The shank is 5/16" diameter and about 1.5" long:
I started with a 3" piece of 1" diameter 12L14 steel that I faced and drilled/reamed on the lathe.  Then I chucked it in the milling vise and milled a 1/4" flat on the top.  Following this I center drilled and drilled 7 holes on the flat for set screws.  The next step was to clamp the bar with the flat against the fixed jaw and mill the relief cuts.  They are ~3/8 wide and test fit on the AXA tool holder.  Finally I tapped the holes for 5-40 set screws.  Here's the assemblage:
Note that the boring bar has a flat on the top, so that the set screws assure a horizontal alignment of the cutting surface.  I also cut both the side reliefs at the same time so that the holder will mount squarely on the AXA holder.
Mounted on the QCTP:
I use the quill of the tailstock to align the holder, and thus the boring bar, with the ways.  After adjusting for height, a first practice cut produced an excellent result.  I'm  pretty happy with 90 minutes or so of shop work to make this.  The other boring bar is a lot smaller, so I think I can make a bushing that will allow me to use it in the same holder.
Offline websterz
Re: Homebrew boring bar holder
« Reply #1 on: December 21, 2009, 11:17:52 PM »
Nicely done! Making your own tooling is so much more satisfying than just buying it.  :dremel:
 :med:
Offline Gerhard Olivier
« Reply #2 on: December 22, 2009, 04:37:29 AM »
Nice holder and very nicely made.  Good work.
Gerhard
Guernsey
Channel Islands
« Reply #3 on: December 22, 2009, 10:43:41 AM »
Nice bit of tooling Kirk. Very easy to make. I've made a few, but not as fancy looking.
