Author Topic: top fuel dragster facts  (Read 31739 times)
Offline chuck foster
« on: December 13, 2009, 11:53:51 AM »
i have followed drag racing for the last 25 years or so. i just found this bit of info on a top fuel dragster and thought i would share it with you guys.
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona.
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747 but with 4 times the energy volume.
* The supercharger takes more power to drive than a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting off its fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence.
Did you know …
… that the nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 7,000 horsepower, about 37 times that of the average street car?
… that one cylinder of the eight cylinders of a Top Fuel dragster or a Funny Car produces 750 horsepower, equaling the entire horsepower output of a NASCAR engine?
… that the gasoline-powered engines of NHRA Pro Stock cars produce about 1,200 horsepower, about eight times that of the average street car?
… that an NHRA Top Fuel dragster accelerates from 0 to 100 mph in less than .8-second, almost 11 seconds quicker than it takes a production Porsche 911 Turbo to reach the same speed?
… that an NHRA Top Fuel dragster leaves the starting line with a force nearly five times that of gravity, the same force of the space shuttle when it leaves the launching pad at Cape Canaveral?
… that an NHRA Funny Car is slowed by a reverse force more than seven times that of gravity when both parachutes deploy simultaneously?
… that NHRA Top Fuel dragsters and Funny Cars consume between four and five gallons of fuel during a quarter-mile run, which is equivalent to between 16 and 20 gallons per mile?
… that NHRA Top Fuel dragsters and Funny Cars use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run?
… that NHRA Top Fuel dragsters and Funny Cars travel the length of more than four football fields in less than five seconds?
… that NHRA Top Fuel dragsters can exceed 280 mph in just 660 feet?
… that from a standing start, NHRA Top Fuel dragsters accelerate faster than a jumbo jet, a fighter jet, and a Formula One race car?
… that a fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time?
… that the fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 pounds, about 20 times greater than the pressure on passenger-car fuel pumps?
… that depending on size and angle, the large rear wing on an NHRA Top Fuel dragster develops between 4,000 and 8,000 pounds of downforce?
… that the 17-inch rear tires used on NHRA Top Fuel dragsters and Funny Cars wear out after four to six runs, or about two miles? Some brands of passenger-car tires are guaranteed for 80,000 miles.
… that it takes just 15/100ths of a second for all 7,000 horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels?
… that it's desirable for an NHRA Top Fuel dragster to race with its front wheels inches off the ground for about the first 200 feet of the run? This ensures proper weight transfer to the rear wheels, a crucial part of a good launch and quick run.
… that the nitromethane used to power the engines of NHRA Top Fuel dragsters and Funny Cars costs about $30 per gallon?
chuck  :wave:
skype:  aermotor8
former hmem member
Offline mklotz
  • LA, CA, USA
Re: top fuel dragster facts
« Reply #1 on: December 13, 2009, 12:28:47 PM »
Read the thread over on HSM...
http://bbs.homeshopmachinist.net/showthread.php?t=38099&highlight=NHRA+dragster
about this.  As they did over there, I detect the pungent odor of BS about some of this.
Regards, Marv
Home Shop Freeware
« Reply #2 on: December 13, 2009, 07:25:46 PM »
what do YOU think is BS about these fact's????
chuck  :wave:
skype:  aermotor8
former hmem member
« Reply #3 on: December 13, 2009, 07:43:48 PM »
So the more you pump into the sport the less you get out of it ?
So the ultimate is to throw 3.7 million at it and not get out of bed ?
John S.
« Reply #4 on: December 13, 2009, 07:55:45 PM »
chuck  :wave:
If Wikipedia is to be believed, the compression ratio is 6.5:1; if you'd injected enough fuel to come close to hydraulic lock, almost all of the burn would take place after the exhaust valve was opened.
This also seems unlikely. These engines will run very advanced ignition to try to maximise power; dieseling can only be controlled by the fuel injection timing. Since top fuel racers allow both fuel and air in through the intake valve, dieseling would cause immediate and massive backfiring and engine failure.
Erm, competition crankshafts are hardened. They'd shatter before twisting.
The sad thing is, Top Fuel dragsters really are works of engineering art - but someone has seen fit to massively conflate their actual achievements far above reality. Unnecessary IMHO.
Offline Rog02
« Reply #5 on: December 13, 2009, 10:11:52 PM »
chuck  :wave:
The static compression ratio measured at piston to deck height may approximate the 6.5/1 level but add on a 10% to 25% overdrive on the blower and see what happens to the dynamic compression.
NHRA rules are very specific!  The timing curves can be altered through electronic means but the fuel curve is set by pneumatic actuators, spool valve and pills.  Ever watch the crew chief open the "toy box" and tweak a few things after watching another car make a pass?  May be the timing, may be the fuel, only the crew chief knows for sure.   The timing may advance for part of the run, retard for the mid range and advance again after the clutch comes in.  Just depends on the data and how the crew chief feels about how much the track will hold.
The current ignition systems are dual MSD (Multiple Spark Discharge) boxes and distributors firing 2 spark plugs per cylinder.  While some electrode erosion is considered normal, the loss of an electrode will put the "hole out" and the hydraulicking of the unburned fuel will wreak all sorts of havoc.  Definitely finding the weakest parts first be it an intake valve (huffing the blower) or ventilating the block by breaking the connecting rod and forcefully ejecting it through the side of your last Kieth Black (Donavon, John Force Racing, Dart, insert your favorite supplier here) block.
The engines are shut down with the fuel to eliminate an explosive situation where liquid fuel is left in the cylinder and the cylinder heat soaks on the return road and explodes.  This happened with dire consequences in the 50s when it killed a couple of racers bringing about a ban of nitro for several years.  Ain't you glad Garlits never got that Hydrazine stuff past the tech guys?
The journals are surfaced hardened while the core and journal webs are left in an annealed state.  A "through hardened" crank would shatter as it could not handle the torsional stresses and harmonics acting upon it.
Ed Iskaderian, Chet Herbert and several other cam grinders have experimented with the "torsional grind" cam concept through out the years.  Mostly on motors of the BBChevy design as the drag caused by the distributor and oil pump drive has a noticeable effect on the rear cylinders.  Most folks seem to prefer a large base diameter design and call that good but there is still some serious discussions held in the wee hours of the morning in dyno rooms all over the country.  With the advent of crank triggered ignitions on about every thing except Fuel and Alcohol cars the discussion is pretty much mute at this time.  The engines used in AA Fuel Coupe and AA Top Fuel cars use a front crank driven ignition drive and crank driven dry sump oil systems so the cam is not as loaded as in the BBC design.
This is stuff spewed forth from an over ambitious track announcer.  Many of the "facts and figures" quoted are out of date.  The onboard data is clearly indicating the engines are making upwards of 8,000 HP these days.
Oh, Yeah I would like to know where I can buy some of that $30 a gallon Nitro Methane.  Last barrel I bought was $54 a gallon and that was 3 years ago.  I'll take about 2,000 gallons.  Nitro is in short supply.  Don Schumaker Racing is setting on a horde of the stuff and I am told there is a line at his door from industry bidding to get it.  The Texas refinery (only one in the states still perc'ing nitro) blew up again, so it isn't producing.  The Chinese stuff is inconsistent so "suspect".
"Speed costs money kid.  How fast can you spend?"
Roger
Come on down.  Spend a weekend with the rednecks.  It might prove very entertaining.
Roger
I'm OLD, I'm TIRED, and I'M GRUMPY!
