Author Topic: how i make spark plugs  (Read 29255 times)
Offline chuck foster
« on: December 12, 2009, 11:54:13 AM »
i start off with a piece of hex bar stock for the metal part of the plug, in this case it is 1/4" hex.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0759.jpghow i make spark plugs
i then thread the plug body to suit the engine, in this case it is #10-40 tpi.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0761.jpghow i make spark plugs
i then make an adaptor to thread the plug body into so i can hold it in the lathe a bore out the body for the corian insulator.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0775.jpghow i make spark plugs
i use an end mill to counter bore for the corian body
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0788.jpghow i make spark plugs
this next pic shows the corian loctited in place (loctite red)
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0785.jpghow i make spark plugs
i then drill a .031" hole from one end of the corian to the other and loctite a piece of .031" spring or piano wire
in the hole. this wire will become the center electrode.i leave about 1/8" of the wire sticking out of the top of the
corian insulator this is where i solder the brass plug wire terminal on.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0804.jpghow i make spark plugs
i then make a copper washer from some copper tubing that i got from a plumbing supply place.
i just part them off on the lathe.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0800.jpghow i make spark plugs
the last picture shows a finished plug with a ruler for size reference.
http://i217.photobucket.com/albums/cc274/aermotor8/SPARK%20PLUGS/IMG_0797.jpghow i make spark plugs
i make my own spark plugs mainly because some engines need a long or short reach plug, so as to get the spark right in to the combustion chamber.
another reason is some times on a small engine the bigger plug look out of proportion to the rest of the engine.
i have run this type of plug in several of my engines and had very little trouble. when the plug gets dirty you just take it out and rub the business end on a piece of fine emery paper to clean it.
i hope this help's those who would like to try making their own plugs.
chuck  :wave:
skype:  aermotor8
former hmem member
Re: how i make spark plugs
« Reply #1 on: December 12, 2009, 06:51:40 PM »
Nice little write up Chuck.
Makes me wonder if one could make a sparkplug for your every day driver if times ever got real bad and you needed a sparkplug?
« Reply #2 on: December 12, 2009, 07:01:20 PM »
Thanks for showing that, I always though spark plugs were more complicated, nice to see they can be made  :clap:
Offline gbritnell
« Reply #3 on: December 13, 2009, 12:39:23 PM »
Hi Chuck, nice write up. When I started out making plugs I used almost the same idea that you use. On some engines I found that the surface gap type plugs would get a little bit of condensation on them and short, on start up mainly. I then started machining mine with a ground strap. These seem to work out a little better. Rather than hijack your thread I'll start another one showing how I make mine.
George
« Reply #4 on: December 13, 2009, 07:22:24 PM »
mr britnell i look forward to your write up on how you make plugs.  :thumbup: :dremel:
the more ways you see something done the better, ideas can be taken from many sources and that is what makes this hobby so much fun.
chuck  :wave:
skype:  aermotor8
former hmem member
Offline sorveltaja
« Reply #5 on: December 14, 2009, 04:47:47 PM »
Interesting work, Chuck :clap:.
Dare I ask even a bit of details of the engines, that you make the spark plugs for? :poke:
« Last Edit: December 15, 2009, 01:50:32 PM by sorveltaja »
Offline ariz
« Reply #6 on: December 15, 2009, 03:11:24 AM »
I'm sorry, but I don't understand how it works
the main electrode seems to be immersed in the insulator and I don't see any secondary electrode from the wall of the spark plug
what am I missing?
« Reply #7 on: December 15, 2009, 05:36:15 AM »
what am I missing?
Ariz
Similar to Surface Discharge Plug ..
Poke around this site .. some info on plugs in general too.
http://www.ngksparkplugs.com/products/spark_plugs/surface.asp
Commercial Item , although not as small as Chuck's plugs ..  :)
Dave BC
« Last Edit: December 15, 2009, 05:52:55 AM by Bluechip »
Offline ariz
« Reply #8 on: December 17, 2009, 10:44:19 AM »
well, now all is clear
thank you Dave  :thumbup:
