Author Topic: Myford Taper Turning Atahment AGIAN  (Read 132061 times)
Re: Myford Taper Turning Atahment AGIAN
« Reply #25 on: December 11, 2009, 11:53:19 AM »
Many thanks Kvom and  deere_x475guy
Rob, glad to see this back up for all of us to have a look at.   I saw it a short while back, then couldn't find it.
Where did you get that delicious color for the ball handle and clamp?  Looks great!
Dean
Thanks Dean ,,i just heat the parts up to get that blue color ,its quite easy to get a range of colors ,,just like tempering steel ,,,i scaled up the method used by clock makers ,,i can do a how to ,,if anyone is interested
Regards Rob
« Reply #26 on: December 11, 2009, 11:55:03 AM »
What a silly question ....  :)
I'm sure it's easy to do .... when you know how  :thumbup:
« Reply #27 on: December 11, 2009, 12:29:36 PM »
Rob, I would love to see a article on how to heat treat the handles to achieve the beautiful finish that you did.  :ddb: :ddb:
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #28 on: December 11, 2009, 01:28:29 PM »
Thanks Rob.  I don't know why I didn't think of that.
Done it many times for bluing.  Brain block, I guess.
It certainly is a beautiful build all 'round!
Dean W.
Shop Projects:
« Reply #29 on: December 19, 2009, 12:01:43 PM »
Cheers Lads
I will do a post on Bluing over the holidays
I mamaged to get the TTA finished today ,well all bar a few small screws ,,
Here is a shots of it fitted to the lathe
The lead screw disconected ,to allow free movement of the cross slide
And a shot of it in action 5 deg tapper
Over all i am very pleased with it ,,now i will have to set too and make up some 2and 3 MT tooling
Regards Rob
« Last Edit: December 19, 2009, 12:17:28 PM by Rob.Wilson »
« Reply #30 on: December 19, 2009, 02:52:28 PM »
I can only watch this thread for a couple of minutes at a time because of the drool factor. Don't want to short out the keyboard. Love your avator too by the way.  :ddb: :ddb:
« Reply #31 on: December 19, 2009, 07:26:26 PM »
Very nice job Rob. Looks very proffesional.
Glad you decided to repost this. It's an encourgement for others to do the same. Thanks.  :clap:
« Reply #32 on: December 19, 2009, 07:53:17 PM »
If you told me that was a commercial item I would have believed you  :bow: :bow: :bow:
Offline Gerhard Olivier
« Reply #33 on: December 20, 2009, 02:26:17 AM »
That is a tool to be proud of that is excellent fabrication.
Gerhard
Guernsey
Channel Islands
« Reply #34 on: December 20, 2009, 04:40:49 PM »
Thanks Lads ,,,,for your very kind coments and taking the time to have a look ,,,CHEERS
Regards Rob
Offline outlawspeeder
« Reply #35 on: December 18, 2012, 11:16:04 AM »
That is the best tapering tool I have seen and plan on doing one in the new year following this layout.
I am looking for the bluing "how to" but can't find it.
Did it get done?  Does someone have a how to?
« Reply #36 on: December 18, 2012, 03:23:01 PM »
Rob, amazing !!!!!!   :drool:
I`m with Dean - please tell us how you got the finish on the handle!
« Reply #37 on: December 18, 2012, 03:39:18 PM »
I have bought this back from 2009.  Rob are you there?
« Reply #38 on: December 18, 2012, 03:45:41 PM »
well dun rob
« Reply #39 on: December 18, 2012, 03:57:27 PM »
Thanks Chris and Bob
Welcome to Madmodder  outlawspeeder
Its a very basic process to build up an oxide layer on the part   , polish your part ,then CLEAN the part and dont touch it with your paws , you will get grease transfer from your fingers ,were gloves , then evenly heat the part to the desired colour and plonk it in a tub  of clean oil .
Edit :  forgot to say 3 years on the blued parts still look as good no rust
« Last Edit: December 18, 2012, 04:35:26 PM by RobWilson »
« Reply #40 on: December 18, 2012, 05:25:59 PM »
You want washers under the heads of those button screws you philistine..........................
« Reply #41 on: December 18, 2012, 05:29:39 PM »
 Geordie philistine if you please John  lol
Your right , i should of actually made my own fasteners  :palm:
« Reply #42 on: December 19, 2012, 06:14:50 AM »
This is very good thread. Very big THANK YOU. I have to print it and mull over to get some pointters.
I appreciate those little bits when you explain reasons for certain desicions like that BMS and welded structures vs. stress relieving part. Any chance for a shot outline for your process...temperature/color hold time, cooling time and "aging". I have turned BMS and MOC shafts oversize, let them turn bananas for two weeks (most pronounced within a day) and then finisturned them. Not very conffident.
Also painting/finishing is bit of mystery to me. Would normal car painting (rust damage fixing and coverup) procedure work?
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #43 on: December 19, 2012, 10:46:10 AM »
Amazing handywork..  I wish i could fit one of those on my optimum lathe. =)
« Reply #44 on: December 19, 2012, 04:10:36 PM »
Hi Rob,
            Nice design features, and a great finish, well done.  Have already a mental picture of my next project,  A TTA  for the ML10.  Need a new welder though, mine is only 65 amp Arc. What size welder would you recommend, and is yours a Mig Welder?  I can see some interesting cast parts I intend to make, so am enthusiatic.
                                                       David
« Reply #45 on: December 20, 2012, 12:54:51 PM »
Hi Pekka
No problem , this is how I go about stress relieving the job , remember my parts are not going to get fitted to the space shuttle ,so everything is done with the mark one eyeball and rule of thumb .
First off SLOWLY and EVENLY heat the parts up to about 750 C a blood red colour (in natural light) then soak at heat for One hour per inch of thickness ,  So if part is an inch thick =1 hour , 1/4 of an inch thick  =15 minutes , get the idea , gets a bit more technical when you have thick thin sections in the same part , But for home shop use just go for working the time out on the thickest part  , Then allow to cool SLOWLY , I just shut the furnace off ,block the blast hole and close the chimney . My furnace is well insulated and it takes a good 24 hours to cool down enough to handle the part ,still warm to the touch. works for me .
Paint ,yes just car paint , the TTA was actually painted with 2K.
Hi Neo   ,,, Why not ?   There are other types of TTA  that fit to the saddle of the lathe if there is no way of attaching it to the bed . My CUB lathe has that type I can take a few photos of it you would like.
Hi Rob,
                                                       David
Hi David
The design is not mine ,I blatantly copied a Myford one LOL , I use MIG ,TIG and Arc , the MIG witch I used on the TTA is 220 amp . What you need to do is decide on how big and how thick your likely to weld then go from there .
A cast ally bracket for the TTA would be just the job  :poke: lets no if you need photos or drawings (I think I still have drawings)
Cheers Rob
« Reply #46 on: December 20, 2012, 02:01:23 PM »
Hi Pekka
No problem , this is how I go about stress relieving the job....
Cheers Rob
Thank you very much. I'll arm mysef with this information, make some parts a little oversize and bring them to my friends lab oven for a "quick spin".
« Reply #47 on: December 21, 2012, 07:38:29 AM »
Hi  Rob,
                    Thanks for the info. Drawings of the bracket and any other parts would save me a lot of time, could then get on with making the patterns. May have to make a new flask, or cast the bracket in two pieces. I have only cast a litre of 'ally' in one pour up to now. Could always follow the Double Boost and give the furnace a new midriff.
Offline ilia-45
« Reply #48 on: December 30, 2012, 08:27:04 AM »
Bravo :clap: :clap: :clap: :clap:
« Reply #49 on: January 04, 2013, 12:59:27 PM »
Rob,
Thanks for the reply back from my Dec 20th post.  I bet you thought this thread was done.  Two years after you started, people are still interested in great workmanship.    Thanks for the info on the bluing.  It looks good even under the plastic angle gauge,yes i saw that.   I’ll try bluing this weekend on some scrap.  It will help to keep the shop warm.
I have gathered some of the parts needed to build my taper for Grizzly G9249, but still working on some of the details.
Again, it is a piece of art.  You have set the bar high and I hope to a rise to this level of workmanship.
To Rob and anyone willing to give advice.
Here are some odd ball questions:
The back side of my lathe is rough cast.  Not a flat mount.  What do I do? Put the lathe on the mill??? The bed weights more then I want to lift.  Mount the plate, true it (grind as needed) and leave it there? Do four mount studs with standoff plates…
I have seen a lot of plans with a dead man bar. Rob, your design works for only that part of the lathe, the first 12-18 inches?  Step in and tell me if my thoughts are wrong.   Is a dead man design really needed?  I don’t do a lot of work out that far to the right and normal I can flip the work…  Thoughts?  Looking for input is it needed?
When you are not using your TTA, do you just leave it loose, remove upper parts, remove all of it and “return it to the museum” for display?
On Rob’s Slider:
He hardened it, the wedge, missing from all photos and text, does it get hardened?   I can see were you may have blued it in one shot.  Is it BSM, or something soft?
Well this got long.  I am adding in some links (hope not to offend) of manuals, sites, to look at before you build.    Some of these are good, some are “here is a thought” and some are, well “you build with what you got to build with”.
So for those that want to look at other plans thoughts:
http://www.wswells.com/data/howto/9_taper_Install.pdf
http://www.strippingknives.com/tools/taper.htm
http://www.gadgetbuilder.com/Taper.html
http://www.homemodelenginemachinist.com/f28/lathe-taper-attachment-6404/
Cross slide modifications required thoughts
http://pics.woodstockint.com/manuals/m1022_m.pdf
http://cdn1.grizzly.com/manuals/h0775_m.pdf
http://content.wmhtoolgroup.com/manuals/man_321442.pdf
Chuck offsets (the what was I thinking thought)
http://www.vintageprojects.com/machine-shop/offsettaperturning.pdf
Last place but an “A” for hitting up the local hardware store to buy pipe:
