Author Topic: Soft MT2 blank  (Read 12430 times)
Offline Gerhard Olivier
Soft MT2 blank
« on: November 16, 2009, 03:22:14 PM »
I got an MT2 blank arbour for ARC at the midlands show to use to make a revolving chuck.
But it wont drill or bore???? to hard -Is there a way to soften it?
Gerhard
Guernsey
Channel Islands
Re: Soft MT2 blank
« Reply #1 on: November 16, 2009, 03:28:30 PM »
It may be case hardened........ :scratch:
Dunno....Heat it and let it kewl naturally....
Re: Soft MT2 blank
« Reply #2 on: November 16, 2009, 03:56:50 PM »
I've machined up quite a few blank morse tapers, her's a couple of links, they are quite tough stuff but you can machine them, have you tried a TC or tipped tool.
Me
http://madmodder.net/index.php?topic=1208.0
http://madmodder.net/index.php?topic=1239.0
Hope this helps
Re: Soft MT2 blank
« Reply #3 on: November 16, 2009, 04:34:01 PM »
Thanks for tips
Tried a tc tip - cut but not enjoyed it .
 Here is the rest of the project.
http://i608.photobucket.com/albums/tt161/geroli/LP617.jpgSoft MT2 blank
Started with a steel bar threaded the end M12 by 1mm to fit the chuck.
http://i608.photobucket.com/albums/tt161/geroli/LP618.jpgSoft MT2 blank
Fitted the chuck to the thread.
http://i608.photobucket.com/albums/tt161/geroli/LP619.jpgSoft MT2 blank
Then made an arbour cut concentric
http://i608.photobucket.com/albums/tt161/geroli/LP620.jpgSoft MT2 blank
Backed the chuck onto the concentric arbour and then machined the spindle to bearing size- drilled and tappen the end for a bearing retention bolt.
http://i608.photobucket.com/albums/tt161/geroli/LP621.jpgSoft MT2 blank
I have replaced the bolt with a cheese head as it is smalled since doing the pic.
Now I have got the bore in the mt2 to size but was going to hold the lot together with grub skrews - but this lot wont drill never mind tapping.  WOULD Locktite be ok around the bearing outers to hold the lot together???
Gerhard
Guernsey
Channel Islands
Re: Soft MT2 blank
« Reply #4 on: November 21, 2009, 02:29:15 PM »
The mt2 blank bored (the finish is not very good)  but as Stew suggested it cut with the TC tip.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0005-5.jpgSoft MT2 blank
Then it was impossible to drill so I made a small oven with 5 fire bricks and heat it up to soft oranje and left it in the oven to cool over as long as possible. Thanks John Rudd . Then drilled and tapped.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0008-3.jpgSoft MT2 blank
After polishing with wet and dry I assembled it
http://i608.photobucket.com/albums/tt161/geroli/DSC_0009-3.jpgSoft MT2 blank
The End
Gerhard
Guernsey
Channel Islands
Re: Soft MT2 blank
« Reply #5 on: December 02, 2009, 01:33:59 PM »
Gerhard
Glad to hear you resolved your problems... :thumbup:
Re: Soft MT2 blank
« Reply #6 on: December 02, 2009, 03:21:58 PM »
Bit late to the party but ....
http://www.axminster.co.uk/product.asp?pf_id=21342&name=groz&user_search=1&sfile=1&jump=44
I've used these on several occasions, They are readily machinable .. with hss or tipped tooling ..
Dave BC
Re: Soft MT2 blank
« Reply #7 on: December 02, 2009, 03:46:00 PM »
ARC also do them and with differing threads if needed... :D
http://www.arceurotrade.co.uk/Catalogue/Blank-End-Arbors
Re: Soft MT2 blank
« Reply #8 on: December 02, 2009, 03:51:42 PM »
That one is the 40mm metric one from ARC but it was no fun working with it but the end result came out fine.
I didn't know Axminster sold them - I have always had very good service from Axminster so worth remembering.
Thanks
Gerhard
Guernsey
Channel Islands
