Author Topic: Arbor spacers.  (Read 25485 times)
Arbor spacers.
« on: November 06, 2009, 06:03:21 PM »
This is a where do I, rather than a how do I.
I am searching for a source of arbor spacers to fit a 1" diameter arbour, and must have the keyway already cut.
There is a bit of a criteria, I only want them to a max of 1/32" thick. 0.005" up to, would be fine.
I have found a supplier in the US, but his only go up to about 3/4" bore, but he sells them at the right price, less than 20 bucks for 100.
If they are around that sort of price, I would take 200.
Can anyone help?
Please, none of the 'why not make them yourself' comments.
Offline tinkerer
« Last Edit: November 06, 2009, 06:12:48 PM by tinkerer »
Tink
Prov 13:19
Re: Arbor spacers.
« Reply #2 on: November 06, 2009, 07:08:27 PM »
Do you like living dangerously John ?
http://www.mscjlindustrial.co.uk/QNB-63265D/SEARCH:KEYWORD/product.html
Listed as 1" arbor shim set, no picture and not in the catalogue £6.85 a set but you have to ring them.
John S.
Re: Arbor spacers.
« Reply #3 on: November 07, 2009, 02:24:10 AM »
Sorry gents, I must have confused you.
I need ALL the same thickness not a range of sizes.
I need to accurately set up a bank of up to 10 thin slitting saws. The spacing isn't critical, but they all have to be the same.
I require something similar to these, but in 1" bore
http://cgi.ebay.co.uk/Precision-Steel-Arbor-Spacers-5-8x-1-x-005-100pcs_W0QQitemZ220225235672QQihZ012QQcategoryZ25290QQcmdZViewItemQQ_trksidZp3286.m7QQ_trkparmsZalgo%3DLVI%26itu%3DUCI%26otn%3D3%26ps%3D6
Re: Arbor spacers.
« Reply #4 on: November 07, 2009, 05:01:25 AM »
Awkward bastich, you can't help some people  :poke:
John S.
Just joking John
Re: Arbor spacers.
« Reply #5 on: November 07, 2009, 05:15:41 AM »
I know you are only joking John.
But being awkward can pay dividends at times.
I get a bit of free tooling or large discounts from retailers by being just so.
So you can now see what direction I need to be going in.
They should be available, but I just can't find out where.
Otherwise it is going to be a very long haul, cutting and grinding.
Offline slowcoach
Re: Arbor spacers.
« Reply #6 on: November 07, 2009, 06:48:04 AM »
I can't find anyone supplying them in the UK, but in the US I found these guys, http://www.newmantools.com/precisionbrand/arbor.htm
Re: Arbor spacers.
« Reply #7 on: November 07, 2009, 08:16:11 AM »
Many thanks Rob, I have emailed them and just hope they will supply to the UK.
The only problem being, there were no pricings for them, and everything else they sell does seem to be very expensive.
We will see
Offline slowcoach
Re: Arbor spacers.
« Reply #8 on: November 07, 2009, 09:03:00 AM »
Found these whilst surfing John. Another one from USA http://www.mjvail.com/ShopAid/steelarbor.html and finally one from the UK http://www.boneham.co.uk/ShowProducts.aspx?CategoryID=177.
Cheers  :thumbup:
« Last Edit: November 07, 2009, 09:16:37 AM by slowcoach »
Re: Arbor spacers.
« Reply #9 on: November 07, 2009, 12:36:36 PM »
Thanks again Rob,
I will definintely chase them up.
Looks like we are getting close.
Re: Arbor spacers.
« Reply #10 on: November 07, 2009, 12:55:09 PM »
I found the Boneham link but that page wouldn't load for me so I didn't post it.
John make sure you are sitting down before you ring them, have a brandy to hand and when you have got your breath back post your result here  :coffee:
John S.
Re: Arbor spacers.
« Reply #11 on: November 09, 2009, 10:45:04 AM »
Everyone who has helped, many thanks.
I have had only one reply from the US and that was asking for everything, right down to the colour of my thong, and still not quoting prices. So they have been kicked into touch
So I called Boneham today, and they do them in a full range of thicknesses, 0.001" and up, for 1" bore with keyway, for 22 pence each (plus vat & postage). So I am very happy with that price, and have ordered 90 off, of varying thicknesses, which will allow me to make up whatever sawpack sizes I need.
Thanks again for your efforts.
Re: Arbor spacers.
« Reply #12 on: November 09, 2009, 11:18:51 AM »
Bogs,
Glad you found them, now are we going to find out what the saw packs are for?  :poke: Or have I missed something?
Re: Arbor spacers.
« Reply #13 on: November 09, 2009, 11:42:18 AM »
No secret Nick,
The saw packs are for making finning on model engines. For round cylinder fins, you cut them on the lathe with a grooving tool, but for finning on straight or irregular shapes, you use a slitting saw.
So If I need to cut say 6 fins down the side of a crankcase, I would use 7 slittings saws to cut the grooves, and the spacers between are set up to whatever width you want the fins. It saves having to do them one at a time, and you also get much more consistent results.
The spacers can be used anywhere you require accurate spacing between cutters. Just an easy way to speed up production of usually many identical items.
Re: Arbor spacers.
« Reply #14 on: November 09, 2009, 12:18:39 PM »
No secret Nick,
Good to hear you got sorted  :thumbup:
You gonna show us some pictures when done please ?
Re: Arbor spacers.
« Reply #15 on: November 09, 2009, 01:01:19 PM »
At one time I was making model engines all the time, and using all sorts of techniques.
When I get these projects out of the way, my model engine designing and making will be resurrected.
This is my Halo project where I was setting up to do the finning on the cylinders in the lathe. This post will be restarted soon.
http://madmodder.net/index.php?topic=1539.msg15474#msg15474
Re: Arbor spacers.
« Reply #16 on: November 09, 2009, 03:31:04 PM »
Kewl project...Best of luck with it.. :thumbup:
I'm tempted to have a go at the Boll diesel aero engine feature in one of the R/C mags... Trouble is dark nights and a cold workshop dont entice me to embark on this...
Apart from the fact that I'm still trying to finish my powered X axis conversion on my mill which is without problems!
Offline slowcoach
Re: Arbor spacers.
« Reply #17 on: November 09, 2009, 03:33:07 PM »
Glad to hear you got sort with the spacers Bogs.
Rob  :thumbup:
Re: Arbor spacers.
« Reply #18 on: November 10, 2009, 08:51:51 AM »
I thought it must be that!  :thumbup:
Re: Arbor spacers.
« Reply #19 on: November 11, 2009, 11:47:45 AM »
Just to finish this topic off, I received the arbor spacers today. They worked out, after all the taxes and postage, just under 33 pence each. Which I am very happy with. Now I know a cheapish source, I will buy a few more in different sizes.
To put John R out of his misery, I went to the shop and set up a basic saw pack. 1/32" saws with a 0.100" spacer pack between each one.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack01.jpgArbor spacers.
I popped the right angled head onto the mill and set it up for milling in the Y axis, it is easier to see things doing it this way.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack02.jpgArbor spacers.
A bit of rough ali plate and a 0.100" depth of cut and the saws were on their way.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack03.jpgArbor spacers.
In less than a minute, the slots were cut.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack04.jpgArbor spacers.
After moving the pack over and eyeballing to basic alignment, I went for another cut.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack05.jpgArbor spacers.
Twelve slots cut in no time.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Slitpack06.jpgArbor spacers.
So I now hope you understand the reason for the spacers I was after. I have lots of slitting saws of the same size and width combinations, even small solid tungsten ones, so I will now be able to cut mass finning with ease.
« Last Edit: November 12, 2009, 03:42:20 AM by bogstandard »
Offline ariz
Re: Arbor spacers.
« Reply #20 on: November 12, 2009, 06:21:26 AM »
ahhh, cut finnings!  :doh:
I didn't understand what you would do with this setup, now it's clear. very neat idea Bogs  :clap:
Offline Davo J
Re: Arbor spacers.
« Reply #21 on: November 12, 2009, 09:32:00 AM »
At least it gave you a chance to have a play and use the new tool.
 My new H/V mill is back together now  :ddb:(finally) just got to get the DRO's back on and I am back in business. I will post some pictures of what I have done in a new thread.
Re: Arbor spacers.
« Reply #22 on: November 12, 2009, 11:39:26 AM »
I will just add, you don't need a horizontal arbour to do this sort of thing, but it helps when you have long cuts or large areas to cover as it is easier to hold the job horizontal.
As you can also imagine, you can use them in the vertical mode in conjunction with a RT for cutting cylinder fins.
You just have to use you imagination and ingenuity.
