Author Topic: How do I decide what sort of engine to make next?  (Read 7451 times)
« on: November 04, 2009, 02:30:05 AM »
It is time to be thinking of the next 'project' which will likely be an engine of some sort.
My little 'nutating engine' looks good on the shelf but next time I will be trying for something bigger, bigger because working tiny does not fit my style and makes the job harder. Maybe in the future I will work smaller, meanwhile I am thinking of a single cylinder engine of about 50mm or more bore, I more-or-less have the basic layout firm in my mind except for the top end of the cylinder which is where everything happens.
So, it could be a double acting steam/air engine but how much air would I need to drive something of that size?
Maybe a Stirling or a flame licker, are the proportions close enough that I could make any of the three types for the same basic crank and cylinder?  Thinking is if the flame licker does not work I could add a displacer and call it a Stirling  or I could add the valve gear and convert to air/steam.
OK, OK, I know I am the one who must find the answers but thats where I am right now. :scratch:
Re: How do I decide what sort of engine to make next?
« Reply #1 on: November 04, 2009, 03:48:08 AM »
Flame lickers are a pig to get running, and I personally wouldn't do one until you have a couple of basic piston and cylinder engines under your belt. The tolerances and friction reduction is the killer, and it is also the same for a Sterling type engine.
I designed and built a modular engine a while back (I am just going thru a blinging exercise on it to get it to showing standard).
The basic layout leaves it open to fitting almost any type of air control to it, I chose to go with a poppet valve and a floating piston in the cylinder head.
This is a rather old and well seen vid of it in it's basic operating mode.
The construction of it is shown here.
http://www.homemodelenginemachinist.com/index.php?topic=612.0
BTW, once you get over 1/2" diameter on the piston, you are starting to get into the realms of a normal air compressor rather than say an airbrush or larger fishtank one.
« Last Edit: November 04, 2009, 03:55:20 AM by bogstandard »
« Reply #2 on: November 04, 2009, 02:41:02 PM »
Very interesting video John and a nice write up on the build which I learned a lot from. Thanks.
One thing for sure this next project of mine will be a design that is refined as build progresses, I will start with some basic ideas and a layout which will be heavily influenced by what can be found under the bench.  It will be difficult to match the connecting rod you have from the shop of B&B! :scratch:
Poppet valves for a steam engine have stimulated the gray matter... :med:
