Author Topic: So you want to buy a new air compressor? here is the information that you need.  (Read 11291 times)
Offline PTsideshow
This is the best site I have found for information and straight explanations on what you need to ask yourself!
http://www.jennycompressor.com/howtochoose.html
All the usual disclaimer apply.
I will say that I'm thinking of hunting up a dealer and kicking the tires on one.
3hp 230v 1Ø 175 psi 80 gallon two stage Vertical 10.7 CFM  $2,294
5hp 230v 1Ø 175 psi 80 gallon two stage Vertical 15.2 CFM  $2,379
They are low rpm pump and motors. and with all the other stuff on them. It should have enough guts and glory for my needs in to the future!
 :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
