Author Topic: new Axminster store Nuneaton  (Read 14869 times)
Offline jim
« on: October 12, 2009, 01:19:31 PM »
Axminster has opened a new store in Nuneaton today
i popped down for a look, with Mrs JOC :bugeye:
they seem to have the whole range there, i was interested in the Lathes :scratch:
Mrs JOC said, that looks a good one http://www.axminster.co.uk/product-Axminster-SIEG-Axminster-SIEG-CQ6230B-910-Metal-Turning-Lathe-570771.htm
got to say it looks like thats going to be me next one, just got save up now :doh:
and extend the work shop :lol:
Re: new Axminster store Nuneaton
« Reply #1 on: October 12, 2009, 02:07:24 PM »
Jimmy,
That is basically the same one I have.
Before going to spend your pennies, or you are going to have a look at it, drop me a PM, and I can tell you what to look out for.
Ask for a list of what it comes with, nothing is mentioned in the specs.
« Reply #2 on: October 12, 2009, 03:00:00 PM »
Jimmy,
John, the photo seems to show pretty much what I got in the way of accessories, the oil can seems to have been downgraded though!  I did not notice the plastic lunch box for the bits either and the key for the 3 jaw is not in the picture but then neither is the chuck presumably being on the lathe!
There is a revolving centre I didnt get and also three tool holders(?).
« Last Edit: October 12, 2009, 03:06:17 PM by John Hill »
« Reply #3 on: October 12, 2009, 04:03:01 PM »
Just found the list, but it isn't as comprehensive as what I got out of Chester UK, and for a lot, lot less cash.
« Reply #4 on: October 12, 2009, 04:16:24 PM »
Whaddya mean Bogs, did you get more bits than I got with mine? :(
« Reply #5 on: October 12, 2009, 05:05:58 PM »
Well, if Mrs JOC thinks that one will suit you, further resistance would be futile!
Strike while the iron is hot  :thumbup:
« Reply #6 on: October 12, 2009, 05:16:22 PM »
Yes, a lot more. :clap: :clap:
« Reply #7 on: October 12, 2009, 05:33:21 PM »
Haha,  well I dont care!  Because MY lathe has the carriage handle in the right place!   :)
« Reply #8 on: October 12, 2009, 05:45:33 PM »
 :clap: :clap: :clap:
Get the measuring sticks out lads............. :lol:
Offline Davo J
« Reply #9 on: October 12, 2009, 11:38:39 PM »
Nice lathe Jimmy,
 I don't think you will be disappointed with it. I had a look at the link and the accessory’s are in the description copied  below. My lathe is similar, I also agree with John,that the carriage handle is on the wrong side. I see that the Chester picture shows the handle on the right but the one of John's (Bog's) is on the left. Has that been changed or is it just the stock picture?
Davo
FeaturesDescriptionSpecificationReviews (1)Axminster SIEG CQ6230B/910 Metal Turning Lathe
• Precision ground, induction hardened bed
• Fully gear driven spindle with hardened and ground gears
• 1,492W single phase motor
• Supplied with a large range of standard accessoriesAxminster SIEG CQ6230B/910 Metal Turning Lathe
A high specification, floor standing, heavy duty metal turning lathe suitable for the keen model engineer, general maintenance and small production facilities. Featuring a precision ground, induction hardened bed, fully gear driven spindle with hardened and ground gears giving a speed range of 75 - 1,400rpm, selectable via the front of headstock mounted gear selection levers. A 1,492W single phase motor, taper roller spindle bearings, range of cross and longitudinal feed speeds selected on a separate gearbox, thread indicator, spindle foot brake, chuck guard safety interlock, guarded leadscrew, splash guard, coolant pump system, work lamp, digital readout on a separate panel. Supplied with a large range of standard accessories including a 150mm(6") 3 jaw self centring chuck, 150mm(6") 4 jaw independent chuck, face plate, live and dead centres. 5 to3 MT reduction sleeve, steady rest, follow rest, quick change tool post with 4 tool holders. Floor stand with oil tray and foot stands. Change gears and toolbox with maintenance tools. The overall capacities are 900mm between centres and 300mm swing over the bed. A gap bed facility gives 450mm swing. Thread cutting facilities in metric with a reversible 3mm pitch leadscrew, the thread indicator giving easy re-engagement of the leadscrew in the correct position. Also supplied are change wheels for imperial thread pitches (note the thread indicator is set for metric only). This machine is supplied with everything you will ever need except tooling. As it's a single phase machine we have supplied it with a 13A plug thus making it also suitable for the very keen model engineer operating from the home workshop.
« Reply #10 on: October 13, 2009, 02:57:10 AM »
There is a slight difference between Axminster's and Chester's version.
Chester fitted another pulley set to the main drive, so you have 18 speeds rather than 9, but up until now I have only needed the lower range set. I suppose a time will come when the faster range is needed. It also comes with a larger 8" four jaw. A monstrous heavy thing, that makes your voice sound like a squeak when you try to lift it. A very kind gent supplied me with a smaller 6" one, which can be handled a lot easier.
As far as I know, Chester has now gone over to the civilised right hand wheel for the saddle movement to help prevent getting burnt by flying swarf.
It still looks like neither has sorted the right hand cabinet out. The coolant tank can only be accessed from the rear, so effectively, if like normal people and have the lathe backed up against a wall, you can't get to the tank to clean it out.
Maybe later, I will look at cutting an access panel in the front, but because I can't see what is behind it, I am a little loathe to go cutting. I will go down to Chesters and have a look inside theirs to see what is behind that front plate.
There is usually a 3 to 4 month lead time on these machines from Chester, I don't know about Axminster. It seems that they can't get enough in to keep up with demand.
It wasn't much, just a much larger industrial chuck guard, a spare 3 jaw chuck (I can now have one set up permanently with soft jaws), a 'few' extra toolpost holders, plus other little bits 'n bobs. But none of these came as standard, only after I complained about a few things.
« Reply #11 on: October 13, 2009, 03:41:08 AM »
Guys, as far as I know the right hand cabinet is completely empty and also as far as I can tell symetrical although if you spin it around I guess there would have to be a new pivot for the foot brake and you would have to move the angle bracket that the 'modesty' panel attaches to.  I am sure that would be the easiest way of making use of the right hand cabinet, even though it is fairly heavy steel and I would not like to weaken by cutting another hole in the front when it already has the hole at the back.
My coolant tank sits on the floor which I can reach since I have put that sloped panel aside.
Yes John, I have seen a glimpse of your chuck guard and I must admit to a little envy as this other one is a real pain when using the collet chuck but I hate removing safety features.
I see a few other vendors offer the two stage pulley system  but really the 2hp single phase motor has such a struggle to get things turning in the high ranges I wonder just how much you can make use of those higher spindle speeds anyway?  Yes, the 4 jaw is too manly for me too, it is so heavy I am actually discouraged from using it which is a pity as there are a few things I put in it.  No doubt about it you do seem to have got a good deal on yours.
Offline Davo J
« Reply #12 on: October 13, 2009, 04:54:23 AM »
From the pictures it looks as though those lathes come with back plate mount chucks like mine did.
https://ishop.gasweld.com.au/ishop/stock/item/580713
Mine also has 18 speeds but it just gets left in low. I picked up a seconded hand (like new) 8" cam lock mount 4 jaw chuck, I do 3/4 of my work in the 4 jaw so I usually use that, it's much lighter to lift. Might be worth a look at for you guy's, if your chuck is not cam lock mount. I haven’t weighed it but I would say it weighs around 3/4 or less of the weight of a back plate one.
It was a strange deal when I bought the chuck. It was on eBay and I asked about a buy it now he also lived close and I could pick it up. He replied and said he would sell the 8" D14 4 jaw chuck, travelling steady, fixed steady and a D14 face plate all new for $125. He told me was he had sold the lathe and the bloke that bought it already had them and didn't want them? Who leaves these things behind when buying a lathe? They were all off a Hare and Forbes (Australia, link bellow) lathe and fit mine perfect as it seems it's only the thread/feed gearbox that’s different between mine and it, which seems to be the same as you fellows have.
https://www.machineryhouse.com.au/Products?stockCode=L183
Davo
« Reply #13 on: October 13, 2009, 08:18:24 AM »
Davo,
The chucks supplied with these machines are fitted with integral D1-4 mounts.
The first thing you should do with any chuck except independent jaw ones is to put a pop mark onto the machine chuck mount. Then by only using the master key hole on the chuck (usually marked with a zero), tighten a piece af bar into the chuck and measure the runout. Check on all three different mounting locations. Once the best reading is obtained, put a pop mark on the chuck in line with the pop mark on the mount, then whenever you change over the chuck, put it back with the pops in line and it will always go back to the best it can be.
It seems that the UK ones are fitted with DRO's now, and I can honestly say it has transformed my machining. To such an extent I have fitted DRO's onto all axis.
It was only a few years ago that it was a total luxury to have X & Y DRO'd, but now it is becoming the norm on the larger machines.
I deliberated for ages which lathe to go for because I had limited space, and eventually I chose the Crusader. Now I have fine tuned it, and now found out that it will accurately cut imperial threads as well, I wouldn't swap it for any comparable sized lathe. It is perfect for what I want it to do.
The music and words are in perfect harmony.
Offline Davo J
« Reply #14 on: October 13, 2009, 11:29:44 AM »
 Thanks John but I have covered all those areas’s, I am only new to the forum not machinery. I have had this lathe for 6 years now (no problems so far) I marked up the chuck back then just after I bought it. I used the V out of the letter punch set to mark it, as it is like an arrow. Also fitted a Miester Xpos3, 3 axis DRO about 3 years ago. It's great as it also has a taper setting for the measuring tapers and setting the compound as well as all the usual features. Years ago there wasn't the range of DRO’s there is now and it was a luxury for me at about $1000 just for the home shop, they are cheaper now though. I understand the way you feel about your lathe, as I feel the same about mine, after adding DRO and all the little bits and pieces as well as adjustments I wouldn't part with it because I know it, and what it can/can't do. It was a step up from my old Hercus lathe, but the old lathe served me well for 12 years. One mod I found a big help amongst others on my lathe was way wipers put them on both sides of the tailstock, the cross slide and compound. After getting swarf under the tailstock once I went through and made them all up to save the lathe ways a bit.
Davo
