Author Topic: ADJUSTING HEAD STOCK  (Read 12071 times)
Offline ozzie46
« on: October 06, 2009, 01:52:17 PM »
  I am adjusting my new Grizzly 10 x 22 and have a succeeded in getting the vertical and horizontal spindle axis within .002 at 15 in. from spindle.
  I put a .625 bar that is from a discarded printer and machined to very fine tolerances in a collet mounted in the spindle. I then mounted 2 dial indicators on the cross slide and compound slide and zeroed them at the spindle chuck, then ran it out to 15 in.s and got it to within .002 thou. both vertical and horizontaly.
  My question is, is this ok or should I try to get it closer?   Or am I just chasing my tail trying to get it closer?
   Ron
Re: ADJUSTING HEAD STOCK
« Reply #1 on: October 06, 2009, 02:04:15 PM »
Ron
0.002" at 15 " is very good.
Offline ozzie46
« Reply #2 on: October 06, 2009, 03:51:17 PM »
  Thanks Stew, I guess I'll button it up and do a test cut.
    Ron
Offline CrewCab
« Reply #3 on: October 06, 2009, 05:20:10 PM »
That's bloody good Ron, most folk would happily settle for that ............ but I suspect most settle for less  ............. well done  :thumbup:
CC
« Reply #4 on: October 06, 2009, 05:30:03 PM »
Ron,
When most standard tolerances are + or - 0.002" say on a diameter or fit, your 0.00013" per inch of length is almost negligible, and nothing to worry about under normal machining in your shop. You could almost say that the force of gravity or a slight breeze could have been causing the runout.
Offline ozzie46
« Reply #5 on: October 06, 2009, 08:37:07 PM »
  CC, Bogs, Thanks for your input. Please know that it is highly valued.
   After I test the tailstock to see if it is centered I'll do a test cut and let you know the results.
  Ron
